All Other Toyota Swaps I4, I6, Lexus V8
1JZ GTE VVT-i into 22R 84 Runner
Old 03-07-2013, 04:42 PM
8784 runner's Avatar
So ive been working on my runner for the past week and figured i should probly starting posting stuff before it gets to far behind me......Pulled the 22r out still mounted to the trany. Dropped the gas tank along with most the electrical and the vacum that the build would not need from the old motor.
I'll be using a R154 bellhousing mated to a R150F out of a 3.4 runner. Using an adapter from Trail Gear ill bolt my stock transfer case to it so my front axle can stay put. Also i will be using a rear sump on this 1jz so it clears my steeiring stabilizer up front
Old 03-07-2013, 04:44 PM
Old 03-07-2013, 04:49 PM
Old 03-09-2013, 06:45 AM
Size:  78.0 KB you can see the input shaft out of the 3.4's is just the right length with the R154 Bellhousing
Old 03-09-2013, 08:05 AM
Discombobulated's Avatar
Looks wonderful if you don't mind how much for the motor? Miles on motor?
Old 03-09-2013, 03:25 PM
I paid $1,650 for the 1J shipped. The miles i do not know. But not many,The harness,block,pulleys,everything is completly clean no dirt grime or oil anywhere. With no evidence of being pressure washed so she should def do some good when it's said and done. I have been talking to Driftmotion.com on getting everything i need. They said the 1jz vvti's bone stock on dyno put out 280-310HP all day no prob.
Old 03-16-2013, 08:04 AM
1J rear sump going on,already dropped it in once. The rear sump clears the steering stabilizer for Hy steer perfect front axle clearence doesnt look like it'll be an issue
Old 03-16-2013, 09:15 AM
niall's Avatar
I would REALLY like to see a bone stock 1jz vvti or not, pull 280 on an accurate dyno.
Every one I've ran (I'm pretty big into the import tuning crowd, and dyno'd quite a few supra's myself) has pulled in 250/250 hp/tq Range.
Still no slouch by any means, and they have a phenominal torque curve, but STOCK you're not hitting 300. That's above what they put out at the flywheel.
Some basic stuff, little bit extra fuel, and crank up the boost a bit, and you'll be creeping closer to that.
I'm not sure how driftmotion is saying those numbers, search supra and lexus forums.
Still an awesome build!
Old 03-21-2013, 11:31 AM
lol 250 is still plenty for me and well over the stock 22r of somewhere right around 100hp
Old 03-21-2013, 11:37 AM
haha well as with any project hey never go as you plan whenyou first start them. What was suppose t be a motor swap has now turne into a boy off fram resto while im at it. Everything was already gutted including the fuel tank. The only thing holding the body and frame together was 8 bolts. So 2hrs after the thought this is what i had.
Old 03-21-2013, 06:51 PM
INFINITY's Avatar
looks like fun!!!!
Old 03-21-2013, 06:59 PM
Black_1985_SR5's Avatar
im definitely watching this one
Old 04-28-2013, 06:15 AM
its been about a month but here are some more pics on what ive done
Size:  139.2 KB... I orderd new front and rear 5inch springs. The fronts are the HD they say 25% stiffer over the regs that they sell. Rear disc brake kit,Twin shifter for the t-case along with the adapter to bolt my orig stock t-case the the 3.4 taco trans i have along with the input gear that is required.
Size:  176.2 KB on each inside rail where the new hangers are welded i did a 2x1/8 inch plate to help reinforce a little bit. The frame is curved inward right at the bend. So i tacked the plate on heated it up and then formed to the frame with c-clamps while it was glowing and then featherd in
Size:  125.3 KB lol when ever im out in the garage for a couple hrs my dog always comes out to tell me hes ready for me to come inside
Size:  139.8 KB I also had to cut my shock hoops and bring them in about 5degrees. Tires at full flex before would rub on them just a little bit. Other then that frame is just about done and ready for paint!
Old 04-28-2013, 06:21 AM
Almost forgot. This is the fuel cell,pum,filter,lines and fitting i orderd from summit. The fuel cell i was gonna build a rack for where the spar tired holder use to be. Problem i didnt like thoe is once the first 90 for the supply is added to the top of the tank it puts it at a total Heigth of 10inches. The tank itself is 7. 30x17x7 just so yall know. Which is way to far for me,the whole point is i dont want it to be to visible below the frame. So i have an idea in my head that im pretty sure i can make look extremly good when said and done. With cutting a whole in the back of the body and then building its own compartment throught the body down into the frame a little bit.
Old 04-28-2013, 06:26 AM
with in the week i was planning on starting to mock up my motor mounts from scratch. I dont think but not fully sure if thiers a combo of mount between the old supras and the runner/pickup frames that'll work for the 1j. Any thoughts???
Old 04-28-2013, 07:10 AM
egesledder's Avatar
The pickup motor mounts welded to the frame aren't that heavy duty, it would probably be best to build your own anyway. That way you can also make them exactly the way you want them for the proper damping control AND you can reinforce the frame behind them. Down the road when you want to push the boost to some ridiculously high number, you won't have to worry about ripping motor mounts off the frame!
Old 04-29-2013, 02:20 PM
i def thought about doing that. But at the same time i have the thought of building motor and trans mounts that bolt to the stock ones. That i could reproduce and sell as a direct bolt in and hopefully get some of my money back out of the swap. If the stock ones handle the domestic V8 swaps and the 1UZ's i would think the stock frame mounts would hold up....But me being wrong is not a rare accurence either lol
Old 06-05-2013, 12:55 PM
Finally had the time to get my frame painted. Took about 7hours total to paint (not including prep). I used POR 15. I did two coats of reg semi gloss then a top coat of there Chassis satin Black. Total Cure time for the topcoats says 3-4 days. Right now im pretty happy with the overall finish. Curious to see how it looks once a get a couple thousand road miles on it.
Old 06-05-2013, 01:02 PM
Also quick word to the wise I thought of while overlooking my pics. If you ever decide to replace your rear frame cross member such as I did MAKE SURE YOU MEASURE IT BEFORE YOU CUT IT OUT!. I just happen to measure mine just as a precaution. Once I cut the cross member out the frame rails pulled in 5/8 of an inch.....Could of been a potentially big problem when the body goes on if the rear body mounts didn't line up.
Old 06-05-2013, 04:57 PM
Can't wait to see this done
Quick Reply: 1JZ GTE VVT-i into 22R 84 Runner
