wiring help please.
Old 09-24-2010, 09:11 PM
sam4runner's Avatar
On my swap i only had to mess with two plugs from the 3.4 side, E5 and IK2. To me yours are the E12 and II3 are the only ones you need to deal with. The other ones should plug into the computer and be left alone. Where is your pin out chart for the E12 plug? How many plugs do you have off the computer?
Old 09-25-2010, 05:55 AM
DWEINBERG01's Avatar
I have 4 plugs coming off my computer: E9 E10 E11 E12. My cornfusion lies with II1 and II2. II2 looks like it is all transfer case related from the 97 t-case. I am getting rid of that so I am not sure I will need to deal with those. II1 looks like it is some transmission stuff. I am mapping E12 right now. Just had some shtuff to deal with. I will get it up today. I really appreciate everyone's help.
Old 09-25-2010, 06:32 AM
sam4runner's Avatar
Just leave II1 and II2 alright alone probably for now. Concentrate on E12 and II3, as well as IH2 and IH1that is all you should worry about
Old 09-25-2010, 03:51 PM
E12 pinout
1 R-Y park/neutral position switch (RL)
2 V-R park/neutral position switch (2L)
3 LG park/neutral position switch (LL)
4 Y to A/T oil temp
5 L-B from A/C amplifier
6 L-O from OD2 to junction connector
7 B-Y OD1
10 G-R PWR to J6 junction connector
12 G-O from speedometer/ comb. Meter
17 R-G to T-case detection
18 W to data link connector 3
20 L-Y from A/C amplifier
22 W-L VSV's/O2 sensor #1 and #2/idle air control valve
25 G-W stoplight switch
26 G-W ADD indicator switch
Old 09-25-2010, 03:55 PM
  #25
26 should be G-B, not G-W
Old 09-25-2010, 05:59 PM
  #26
sam4runner's Avatar
Okay for the +B make the Y like i said earlier.
Let me know if you can understand my diagram lol, I tried to explain it the best i can. All i know is i did it this way and it worked fine.
Old 09-27-2010, 03:08 PM
  #27
here is what i have so far
Can someone check my work? thanks.
E12---------II3---------IH1
1R-Y -----19R-Y
2V-R------4V-R
3LG-------3LG
4Y----------------???????
5L-B--------------------7L-B
6L-O--------------------4Y-G
7 B-Y-------------------21Y-R
10G-R------------???????
12G-O------------???????
14B-W-----26G-Y
17R-G------------???????
18W-------24BR--------9B-L
20L-Y------------------7L-B
22W-L-----16W-L------16W-R
25G-W-----------------5G-W
26G-B-----9G-B
21Y-R----------------19P
22G-W---------------18G-W
Old 09-28-2010, 09:19 PM
  #28
ttt
Top
Wanna make sure my thoughts are on point.
Old 09-29-2010, 01:10 PM
  #29
yodathespian87's Avatar
Here is my thread and what I did. Maybe it will help. https://www.yotatech.com/forums/f160...thread-206686/
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
tj884Rdlx
08-28-2015 12:04 PM
ToyoToler
08-08-2015 08:43 AM
Daneums
07-28-2015 11:57 AM
80Truck
07-24-2015 03:12 PM
Quick Reply: wiring help please.
