Vasinvictor's budget 98/3.4/Auto into 95/3.0/Auto
Old 02-14-2012, 05:02 PM
  #41
SacRunner's Avatar
Assuming the engine ran fine before it's accident, I would look at everything you touched in the fuel system before you start tearing into the top end of the motor chasing computer controlled parts (which you didn't touch).
Off the top of my head:
  • Fuel supply hard line (from filter) to the soft line on the engine
  • Supply line at the banjo bolt going into the fuel rail
  • Return line coming off the fuel rail
  • Return line connecting back to hard line (on the 4Runner's body)
Old 02-14-2012, 07:29 PM
  #42
vasinvictor's Avatar
OK, I was trying to power 1 leg of the COR off IH1 22, which is for a manual trans truck. I simply unpinned, and repinned into IH1 15, which is for the for an auto. I'm still not quite clear on how that made the fuel pump constantly run and cause the injector pulsing. Turned key and it all sounds good. I'll try to crank it tomorrow in the daylight.
TLDR; Auto guys for COR wiring use IH1 15 (for auto) , rather than IH1 22 (for manual)
Old 02-14-2012, 07:42 PM
  #43
spinyard's Avatar
whatz the part number for your alternator belt thats shorter?
Old 02-14-2012, 08:36 PM
  #44
I meant to comment about that. I'm back to using the stock belt. The shorter one caused the alternator to get crammed into the stock lower radiator hose.
Old 02-15-2012, 02:10 AM
  #45
4x4runr's Avatar
Nice progress
Old 02-21-2012, 09:40 AM
  #46
OK, motor cranks over finally. I have spark, verfied by taking 1 plug out and cranking motor. I have raw gas running out of the manifolds and spilling out on to the ground. It seems like a LOT of fuel. Spark+too much fuel=not running.
Old 02-21-2012, 09:58 AM
  #47
http://youtu.be/Jv6qEjuBdHY
Old 02-21-2012, 10:29 AM
  #48
I got it to hit a time or two. I pulled the EFI fuse and cranked it until the gas quits dripping from the manifold. I put the EFI fuse back in, and immediately upon cranking it'll hit a couple times before pouring gas again. Yall think stuck injetors? Motor did sit for a couple years. The only problem I have with this theory is that when I unbolted the fuel line while in the donor, it still had fuel pressure at the banjo bolt. If injectors were stuck open, it should not have had any pressure, right?
Old 02-21-2012, 11:52 AM
  #49
I took the plenum off, injector rails, and pulled each fuel injector. I couldn't blow through any of them. They all looked like good clean injectors.
As a side note, what pleasure to work on this motor compared to the 3vz. It was a nightmare to do anything on the 3.0.
Old 02-22-2012, 04:54 AM
  #50
Help anyone?
Old 02-22-2012, 07:13 AM
  #51
[YOUTUBE]http://youtu.be/aH5-KKOEINI[/YOUTUBE]
I just reassembled the motor and now it works?! I don't know if I didn't have the FPR hooked up to vacuum, or it was a couple of vacuum lines that I plugged up, or what. It's alive!
Old 02-27-2012, 08:05 AM
  #52
Rolled the doner over so I could get to the exhaust and crossmember
Redrill the driveshaft flange to match the newer transfer case output flange. Be sure to mark the driveshaft and flange so they go back on in correct phase. A good bit and some cutting oil is necessary for this.
1/4" plate for transfer case adapter. I dont' have a picture, but I drilled 4 holes in this plate on one end to bolt to the stock crossmember, and 2 holes in the other end to bolt to the doner's crossmember. Bolt on affair, so that it's easily removeable when I get my adapter and gear driven case ready to install.
Here's a picture of the adapter installed. You can see that it bolts on top of the stock crossmember, and to the bottom of the doner's crossmember. This is for short term use, but I suspect it'd work fine long term too.
And the driveshaft bolted back up
I screwed the console down using a self tapping metal screw with a washer on top. It feels really solid. I still have to wire in the shift lock release. I have the wires identified, just haven't cut and spliced yet. I didn't worry about reinstalling the transfer case lever b/c it wouldn't be functional anyway.
I reinstalled the front bumper (with obvious modification) using 4crawlers bumper brackets that I got with the body lift.
This morning I drove it down to the exhaust shop. Since I am running the '98 transfer case which is driver side drop, it's a very tight fit for exhaust to snake around it. I won't be able to fit a cat converter in there. I am mainly interested in getting the o2 sensor plumbed in. It runs pretty good in open loop, but once it's warmed up and starts going closed, it runs like poo. I'm hoping that getting the o2 sensors installed will help that.
Old 03-01-2012, 01:28 PM
  #53
And here's what 30 mins and $30 of exhaust work gets ya. There wasn't room for the cat, so I deleted it for now. I'm using both o2 sensors and stock 3.0 muffler. It sounds nice and throaty at idle. I had to extended the o2 sensor leads about 6" and 12".
I got the exhaust done a couple days ago and have been extremely frustrated that it still ran like crap. I started testing every thing under the hood, all checking out fine. My latest effort was to finally wire up the ODBII connector so I could use a scan tool to try to diagnose it. While wiring it up I found that I never hooked up B+ (e12 23 w-l) to the ECM! I've checked my wiring 20 times, but never caught this. Hooked it up, and she runs BEAUTIFULLY!!! I'll get a driveby video soon, but for now yall can find me tearin' up the streets. (I'm still just 2wd)
I still need to install adapter and transfer case, do the tacho mod, get the speedo working, and make sure the A/C and cruise control are working properly.
Old 03-01-2012, 06:36 PM
  #54
4x4runr's Avatar
WOOHOO! Good job and Grats!
I haven't touched mine in the last few weeks. Been really busy at work and still can't find an ECU out here to test
Old 03-07-2012, 07:43 PM
  #55
I got the AC going today!
All my efforts to work around the charged compressor while motor swapping paid off. It's super easy, once you know how to do it I used the 3.0 compressor and swapped the 3.4 pulley on to it (for the serpentine belt, the 3.0 pulley is a v-belt) and retained the stock A/C amplifier. I left the stock A/C system COMPLETELY UNTOUCHED, except for: splice the "A/C amplifier to Magnetic clutch" (IH2 15) wire into the new harness (II3 25). Off this spliced wire, run a new wire directly to AC1 on the new ECU (E12 16) AND, if your recipient originally had an auto trans, you will have a Pink wire at IH1 19 that originally went to and A/C temp cut switch. GROUND THIS. Do not hook up the original "A/C amplifier to ECM ACT" wire. Leave it unhooked.
I used several of UKRunner and Hamish's posts to gather this info. Just reposting it for more search references for future swappers. I was frustrated it wasn't working until I found the little nugget about grounding the a/c temp cut switch. I'll be working on the cruise control next, and by contrast it looks a lot easier. There are identical matches for all the wires in the old and new harness. I hope it's plug and play.
edit: edit: "How to: A/C for your 3.4 swap" is located here
Old 03-07-2012, 08:33 PM
  #56
dntsdad's Avatar
Originally Posted by vasinvictor
I got the AC going today. All my efforts to work around the charged compressor while motor swapping paid off. It's super easy, once you know how to do it I used the 3.0 compressor and swapped the 3.4 pulley on to it (for the serpentine belt, the 3.0 pulley is a v-belt) and retained the stock A/C amplifier. I left the stock A/C system COMPLETELY UNTOUCHED, except for: splice the "A/C amplifier to Magnetic clutch" (IH2 15) wire into the new harness (II3 25). AND, if your recipient originally had an auto trans, you will have a Pink wire at IH1 19 that originally went to and A/C temp cut switch. GROUND THIS. Do not hook up the original "A/C amplifier to ECM ACT" wire. Leave it unhooked.
I'd love it if someone, and when I say someone I really mean you since you are the latest to score a victory on the AC , did a detailed write up with some great pics to add to the stickies. I have a feeling that as summer approaches we will get 100 posts about AC very soon.
Old 03-07-2012, 08:51 PM
  #57
I'll get to work on it. I would love to contribute in some way.
Old 03-07-2012, 09:11 PM
  #58
dntsdad's Avatar
Looking forward to it. Be a great addition to the forum.
Old 03-08-2012, 10:26 AM
  #59
SacRunner's Avatar
Did you do anything to retain the A/C idle-up functionality?
I've read a few swaps (I don't remember which ones) where its been done using either the 3.0 AC VSV (tied into the 3.0 A/C amp or the ECU somehow) or the 3.4 ECU to directly increase engine speed.
Either way, congrats on getting the A/C up and running.
Old 03-08-2012, 11:06 AM
  #60
I haven't done that. When my compressor comes on, the engine RPMs do drop, but doesn't stall out. The 3.4 ECU doesn't seem to compensate for it like I've read other places. I will wire that up and report back and try to include it in my upcoming "sticky post". For now I'd say if you didn't wire it up, you'd probably be fine.
Quick Reply: Vasinvictor's budget 98/3.4/Auto into 95/3.0/Auto
