Vasinvictor's budget 98/3.4/Auto into 95/3.0/Auto
Old 01-20-2012, 06:54 AM
andersej's Avatar
Allright! Be carefull with her
Old 01-21-2012, 01:23 PM
vasinvictor's Avatar
Once you remove the 10mm nut from the center of the clutch, you'll notice the clutch part is threaded. I used this bolt, don't recall the size to put back into the hole and remove the outer clutch
Snap ring that holds the pulley on
All apart
THIS. Don't lose this. It goes on top of the shaft to space the outer clutch from the pulley side. If you don't put this back in, the compressor will stay engaged all the time.
Put back together with 3.4 pulley and clutch
All the rusty stuff you see is the old 3.0 clutch and pulley. 3.4 stuff was nice and shiny going back on. I tried to finish up my wiring conversion harness, but the shrink tube I bought was too big, so now I get to unsolder about 10 connections
Old 01-23-2012, 04:54 AM
808-3VZE's Avatar
Talking
All apart
Nice job on the ac. Nothing like a cool ride with a 3.4 swap!!!
Old 01-23-2012, 05:19 AM
Nothing much to say here...
Old 01-23-2012, 06:45 AM
  #25
ultimase's Avatar
Wow you work quickly. I have to admit I am dreading the wiring harness aspect of this. I'm looking at the adapter you've made and I'd like to do the same so I can solder it together while being inside the house rather than repinning everything out in the cold.
I'm trying to figure out though. I recognize one of the plugs as one that plugs into the donor ECU, and one of the plugs that plugs into the body harness of the recipient, but I have to admit I'm at a loss of the other three plugs. Any insight?
Old 01-23-2012, 08:15 AM
  #26
Hope this helps. Now I haven't wired in the OBDII yet, and I might have to do something with starter relay leg, but haven't gotten to that yet.
Old 01-31-2012, 10:41 AM
  #27
1.5" Body lift from 4Crawler- kit C+FB (standard 2" blocks, standard hardware, Front bumper brackets) $110 shipped Took about 1.5 hours to install
Fixed a couple tranny wires. I bent the bracket downward to give some more distance between exhaust and wire loom. I've got some convoluted heat shielded loom coming tomorrow to put over these wires, and the trans kickdown cable.
Fuel line flipped, and return line re-routed
Things I still need to do:
1. extend the start trigger wire
2. install motor
3. build battery tray
5. ???
6. profit
Old 01-31-2012, 11:20 AM
  #28
Also, I can't find reference to this situation anywhere on the whole wide internet. Auto swap guys, make sure you get a top shift gear driven case. A forward shift like I got will not work. Here's the factory auto/trans next to the 5speed/transfer case. So now I have a transfer case and 5 speed for sale
Old 02-04-2012, 12:17 PM
  #29
It's a GOOD day
Corrugated heat shielded wire wrap where trans wires are near exhaust.
Took about 15 minutes to lift it up and in- transmission and all. It was an easy fit. Watch out for the transmission dispstick tubes. I bent mine up. I had to take the power steering tensioner bracket off to fit the A/C compressor back in.
Old 02-04-2012, 03:14 PM
  #30
4x4runr's Avatar
Nice, can't believe it only took you 15 mins to mate them together....took me about 30 lol!
Old 02-07-2012, 07:20 PM
  #31
Yotahawk's Avatar
OK I am researching this EXACT swap. Ive got a 93 3.0 auto and am swapping a 2000 model in. I wanna keep the donor trans(I think?) but have no idea how to get the ds to the other side, other than an adapter. So is what you are saying is I can simply keep the 3.0 transfer case and it bolts to the back of the 3.4 trans?
Old 02-08-2012, 05:52 AM
  #32
There is no way your stock 3.0 transfer case will go onto your newer transmission. The picture above shows the stock transmission and transfer case (top) next to the an '83 5 speed and gear driven transfer case (bottom). If you want to run the newer transmission, you MUST get an old top shift 4 cylinder transfer case, and Marlin or Inchworm "Tacoma" adapter, to get your front driveshaft on the correct side.
Old 02-08-2012, 08:03 AM
  #33
cjsgarage's Avatar
vasinvictor,
can't you convert the t-case you have to top shifting?
http://www.marlincrawler.com/transfe...conversion-kit
Old 02-08-2012, 08:32 AM
  #34
I could, and still might. I am putting the stock transfer case in for now and leaving 4x4 inoperable. I want to make sure the motor will run (it's been sitting for a couple years) and the transmission will shift out nicely before spending any more money on adapters or top shift kits.
Old 02-08-2012, 11:19 AM
  #35
I finished my battery tray. I used machine screws and countersunk them a bit and then used a lock washer and a locking nut on the bottom. The 3.0 fuel injector rail black spacers were perfect to level the tray. I also had to cut off the plastic guard that covers the steering shaft knuckle thing because of clearance issues.
Old 02-08-2012, 04:25 PM
  #36
Yotahawk's Avatar
Originally Posted by cjsgarage
vasinvictor,
Now Im confused again...LOL So I CAN use the 3.0 liter tcase? W/ the Marlin topload adapter? Or do I still need another plate adapter to run btw the tcase and the trans?
Old 02-13-2012, 08:51 AM
  #37
Coming together. I ended up drilling out the rivets on the stock battery tray to have more vertical room for the stock intake box. It probably would have fit without removing the tray.
Trans cooler lines needed to be rerouted underneath the steering stabilizer bar. I disco the bar, bent the lines down, and reconnected.
An A/C line hits the UCA. Hopefully a soft bend will alleviate this problem.
Flipped the coolant tank bracket and cut some vertical bracing so it'd sit flush
Also had to cut some of the rad support stuff because my battery tray was too close.
I got a "shorter than stock" alternator belt for a little more clearance. I'm now wishing I had not gotten Dremel happy and cut my steering shaft shield off Total length of the alternator belt is 41.25" vs the stock 42.625". Seven-eighths of and inch shorter.
Heater hose routing. I removed the rear heater and lines FWIW. The hose coming from the driver side firewall gets routed of the passenger side outlet of the block. I just used the hoses I had available and they worked without too much stress.
Looking like an engine bay again.
Got the hood on. Zero clearance issues with 1.5" body lift.
I need to tackle the EVAP, but the nipples on my VSVs are broken on the 3.4 harness. I really want to completely take out the can and do away with it all like RobD, but I DO want to retain a functional CEL, and don't want it constantly on. I'll be studying the EWDs to see if I can trick the EVAP into thinking it's working properly, while removing the whole mess. It'd look really clean without it in there.
Old 02-14-2012, 03:34 PM
  #38
Well I turned the key on tonight to IG2, didn't try to start it. The whole time I left the key "on" the fuel pump was running and there was something clicking under the hood. It started smelling gassy. I unplugged the EFI 15 amp fuse and the fuel pump quit and the clicking quit. I am guessing the injectors, maybe just one of them, is squirting gas. I'm not really sure why yet. I didn't touch the engine harness. Anybody have any quick ideas?
Old 02-14-2012, 04:04 PM
  #39
ultimase's Avatar
You should wait until someone that knows what they're talking about comes on, but the only thing I can think of that would have any interaction with the fuel pump would be the COR wiring. As you said the engine harness is largely untouched.
Old 02-14-2012, 04:10 PM
  #40
Thanks that's the first place I'm going to check. This is going to drive me nuts til I figure it out. I've checked this darn wiring twice completely before installing.
Quick Reply: Vasinvictor's budget 98/3.4/Auto into 95/3.0/Auto
