Top shift or forward shift with automatic?
Old 01-29-2012, 10:09 AM
vasinvictor's Avatar
May have just messed up and bought a forward shift transfer case attached to 5 speed for my auto 3.4 swap. Can I use the forward shift? Or should I take it back. I don't want to buy a top shift conversion. Fast help would be appreciated.
Old 01-29-2012, 10:34 AM
waskillywabbit's Avatar
Not getting what you are trying to do.
:wabbit2:
Old 01-29-2012, 10:48 AM
3.4 swap with doner 340f auto. I just bought a gear driven transfer case (still attached to 5 speed) to put on the auto with the inchworm adapter. It's a forward shift instead of top shift. Will it work?
Old 01-29-2012, 06:01 PM
R.DesJardin's Avatar
It depends on which fwd shift t-case you have, I have been told there are two different fwd shift rod lengths. I have spoke with someone who did the fwd shift swap you are speaking of. Get out the tape and measure everything up. A 3.4 with an auto will be a great setup for wheelin' IMHO anyway, but some say I'm biased.
Old 01-29-2012, 06:15 PM
Maybe I'm missing something obvious. With the forward shift, the xfer case lever is physically on the 5speed (which I am not using) rather than the transfer case itself. So when I chuck the 5speed, out goes my lever too. Somebody talk some sense into me.
Old 01-29-2012, 06:22 PM
yotaman85's Avatar
I think I'm as confused as you.
Old 01-29-2012, 06:24 PM
yotaman85's Avatar
What truck do you have and were did the t-case com from?
Old 01-29-2012, 06:33 PM
1995 4runner recipient, 1998 4runner doner. I'm using 3.4 and doner's automatic trans. I just bought a gear driven case (still attached to 5speed trans, which I am NOT using) from an 83 Toyota truck. It appears that this gear driven case is a forward shifting unit. Will it work with the doner automatic and an inchworm adapter? I don't know how to explain it any better.
Old 01-29-2012, 07:04 PM
yotaman85's Avatar
????? put it in, you should be fine.. but im just guessing.
Old 01-30-2012, 03:52 AM
OK, just checked out the pics in your build. Should have looked before or maybe having them posted here would help? I don't think it will be a direct bolt up with a fwd shift case. Looks like you need to do some mocking up of parts.
Old 01-30-2012, 05:22 AM
Des, I just found you on pirate- nice build! I guess the auto swaps are not common at all. I can't find any mention of needing a top shift case only for an auto swap any where on the interwebs. Sitting them side by side helped me realize it's not gonna happen unless I get a top shift converting kit, which costs almost as much as I paid for the 5speed and xfer case.
Can anyone confirm that this won't work with certainty.
Old 01-31-2012, 03:22 PM
donomite49's Avatar
yes you need a topshift tc. you can look at the ors website on the engine conversion section. tells you what you need to know. doin the same thing myself.
Liadrin
04-25-2022 02:54 PM
BeMiceElf
10-10-2015 09:40 PM
Tykiller1994
08-10-2015 07:49 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Top shift or forward shift with automatic?
