superchiem's Toyota RV 5vz Swap
Old 12-06-2011, 06:46 PM
  #41
superchiem's Avatar
Talking
I got some stuff done this week.
First I cut behind the passenger-side exhaust manifold flange. Then cut the cross over. We tried rotating it toward the transmission and welding it in place, but we were having to much trouble with the metal.
We ended up shoving a pipe in the cross over coming from the driver side and bending it up to match the height of the passenger side.
So I marked it with white out and tacked welded it from the inside. We still had trouble welding it so I took it to an exhaust shop and guess what! They said the cross over is stainless steel. Thats why we were having so much trouble.
The transmission is bolted in. Driveshaft is installed and fits perfectly. Still I have a lot of work, but I think finishing the cross-over was the biggest hurdle thus far.
Old 12-06-2011, 07:57 PM
  #42
aferg's Avatar
Great work !!! Thank You for all the pictures!
A.
Old 12-08-2011, 09:18 AM
  #43
superchiem's Avatar
A.
Thank you! Getting closer everyday. I can't wait to start it lol.
Old 12-08-2011, 09:40 AM
  #44
Cole Brooks's Avatar
Sorry if I missed it, but what was your intent in chopping the y-pipe to keep right-hand dump?
I mean, isnt it still obvious thats its been modified?
No disrepect.
Old 12-08-2011, 09:43 AM
  #45
Also, if you do decide to make a custom piece, I have a legit jig waiting to be used again...
Old 12-08-2011, 01:55 PM
  #46
superchiem's Avatar
No disrepect.
Hey Cole,
The smog ref doesn't care if its modified with in reason. It has to be passenger side drop w/ 2 cats behind it. I wish I could have just went with a drive side drop, but just because of the CA smog ref I have to do it this way. How'd you get past the smog ref? Seeing that you are from Vista, CA and all.
Old 01-03-2012, 06:42 PM
  #47
superchiem's Avatar
Talking
Got back to working on the RV again.
I needed a shorter Alternator bracket. So I cut it and re-welded it. I also used a shorter belt:
Napa micro-v belt # 25-040405
From the adjustment bracket notch to the first bend of the bracket should measure around 2".
The adjustment bolt was too long so I cut it where the bracket starts bending.
Although I shorten the bracket I can only fit an open end wrench between the bracket and steering box. Probably could have shorten about 1/4" and still have plenty of adjustment, but I don't want to do it again.
Old 01-03-2012, 06:54 PM
  #48
vasinvictor's Avatar
Nice work on the alt bracket. I may have to borrow that idea. You think about 1 1/2" to 1 9/16" to the first bend would be about right?
Old 01-04-2012, 04:42 PM
  #49
superchiem's Avatar
Talking
I would do 1 3/4" if I did it again. The only reason I would do that is because it would fit one of those ratcheting wrenches.
Also to fit the adjustment bolt in the bracket you have to pull on the belt to get all the slack out. If you cut it too short you might have trouble getting the bolt in.
Good luck!
Navy
Old 01-18-2012, 08:22 AM
  #50
superchiem's Avatar
Took a giant step back a week ago. I needed to drill and tap the threads for the column shifter bracket because I didn't swap bell housings. I snapped a bolt in there then snapped the extractor in there. So I ended up pulling the drive shaft, tranny mount, and tranny fluid lines. Then swapped bell housings.
5vz bell housing on the left. 3vz on the right.
I drilled out the hole for the starter on the 3vz bell housing because it is threaded. I wanted to use the 5vz starter just because its newer.
Old 01-23-2012, 09:45 AM
  #51
superchiem's Avatar
Talking
Small update
Just installed the battery tray. I had help from my dad, but he has a rush rush personality, therefore it didn't come out as clean as I want it. :rolleyes: Oh well the battery and paint will cover the ugliness.
If you use the battery tray from the 4runner. You have to make it sit lower other wise the battery is pretty close to the hood when you close it.
Old 01-28-2012, 07:07 PM
  #52
superchiem's Avatar
Here is the battery tray painted:
Basically the overflow tank had threads on the mounting bracket. I wanted to put bolts through the over flow tank bracket and battery holder to sandwich them together. So I drilled the overflow bracket threads. I then cut the battery holder and welded a piece of metal perpendicular to the battery holder, but parallel to the overflow mount. Drilled two holes and welded some nuts on the other end. That was harder to explain then the actual work.
Old 02-26-2012, 08:20 PM
  #53
superchiem's Avatar
Its been a while, but started collecting pictures and things. Started wiring finally. Its getting interesting thats for sure :lmao:
Here is the fuse box:
You first need to pull the 80 amp alternator fuse. There are 2 clips that you need to release on each side of the fuse. Then you just push down on the fuse itself. I forgot to mention you have to disassemble the bottom of the fuse box, which isn't difficult.
This is how the stock setup is. You have to replace that white cable with a larger cable and wire it toward the new battery location. I used a 8 gauge wire from an $30 amp kit from fry's electronics.
Unbolt the terminals.
I hacked off the crimping area for the white cable.
Bolted the new 8 gauge wire on.
Plugged the fuse back in.
I went around the front of the engine bay and to the battery. I zipped tied the new cable to the harness that was already in front of the radiator. Hopefully the excess heat doesn't cause to much resistance here. I'll possibly move it if it causes me problems.
Believe it or not have I had no idea where the original main ground was located. I found it on the 5vz block.
I'll take a better shot later.
Wiring is hard to photograph when you are in the zone. I'll try to keep it up, but I won't keep any promises. I'll get my brother to film on how to release terminals from connectors on safetydang tv.
Thanks for looking!
Navy
Old 02-26-2012, 08:34 PM
  #54
superchiem's Avatar
Also anybody know some part numbers for some plug and play heater hoses that are at the rear of the engine?
Thank you,
Navy
Old 02-27-2012, 05:33 AM
  #55
Thank you,
Navy
I was able to reuse my old ones without having to buy any more. I know others have done the same thing. There's a little stress on some, but nothing crazy.
Old 02-28-2012, 06:30 PM
  #56
spinyard's Avatar
as far as the rear of the engine i used the existing 3.0 heater valve, with all hoses and the other heater hose off the block i used one from the 3.4 and cut it a little bit... i used the stock lower radiator hose with inlet hose from the 3.0 bolted to the 3.4 and the upper i just matched up @ autozone today ill post the part # later but after i cut about 2" off one end it fit perfect
Old 03-30-2012, 10:21 PM
  #57
superchiem's Avatar
Talking
Thanks for the help fellas.
Thanks for all the comments. Sea Jay, I hope your motor roars to life soon.
Small update for things that had to be done.
My house is going to be swarming with relatives, so I am having some sleep in the RV. That means no dash or instrument panels sitting everywhere in the camper. So I put the dash back together and installed my T100 SR5 gauge cluster. I believe the 5vz oil pressure sensor may work with the this, but I'll do a voltage test and see if its the same.
I needed to get the RV off the jack stands, so that meant putting on torsion bars and the rest of the suspension components. I first needed to route the tranny wires and o2 sensor wires. One of the 02 connectors broke when I pulled the motor for the 3rd time.
I found the exact connector from the window washer pump.
Pulled out the lock.
Pulled out the terminals.
Do them one at a time.
Done!
So torsion time!
And shes back on the ground!
Don't worry guys April 21st is the wedding. Then we'll be back on the projects.
Old 03-31-2012, 07:23 PM
  #58
spinyard's Avatar
How Ironic you are being married on my birthday april 21st! Ill be 35 ... Your progress looks good! Where exactly are you checking the voltage for the sending unit? I have a similar dash I just got so i can add a tach and I want to be sure I use the right oil pressure sending unit. I wonder If I ohm it out if that will tell me?
Old 04-03-2012, 04:06 PM
  #59
superchiem's Avatar
Happy early birthday! You got some skills for being so young. I had a haynes manual that showed me what the voltages it should be, but I can't find it anywhere. Maybe I saw it online somewhere. The ohms could possibly tell you, but we need to find out if the 3vz ohms are the same. My sr5 combo meter is a 93 T100, which is from a 3vz. Not sure where your combo meter came from.
Thanks for looking!
Navy
Old 04-09-2012, 08:19 AM
  #60
superchiem's Avatar
Looks like a change of plans for the fuse box. I am going to use the 4runners fuse box. I have to add a few relay and fuses if I want to use the older style.
Anybody know what the 8 wires to make the engine run are, in order for me to turn the rv around?
Thank you,
Navy
Quick Reply: superchiem's Toyota RV 5vz Swap
