Rayl82's 3.4 swap
Old 01-30-2008, 04:11 PM
Elvota's Avatar
That really sux.
Where was the source for the next 3.4? Local?
Why put the 3.0 back in if the 3.4 is on the way?
Old 01-30-2008, 04:30 PM
Jason4X4's Avatar
it isn't going back in, that was a picture from when we pulled it out. Just trying to make a funny...
The new engine is coming from greenleaf, they just couldn't deliver it today.
Old 01-30-2008, 05:30 PM
Jason4X4's Avatar
well, got ahold of the guy we bought the engine from, and he is saying now that it came out of a non running truck that had a bad fuel pump, so it was never checked. he says he didn't misrepresent it, and that it does indeed only have 19k on it. he said he priced it cheap because it came out of a non running truck, woulda been nice to know then. he also said that we coulda checked it before we bought it, but why would we when it only had 19k on it, if he would of said it didn't run, we would of checked it.
Old 01-30-2008, 06:11 PM
881stGenRunner's Avatar
wow man that really sucks. That guy you bought it from sounds pretty shady if you ask me. Is the wiring and ECU from it at least any good? Hopefully you dont have to buy all that again.
Old 01-30-2008, 06:15 PM
  #25
Jason4X4's Avatar
I dunno, it was an auto harness and ecu, so we actually got one from a manual so it doesn't set trans codes. but the harness and ecu that we got from the manual is good, since we already had it running.
Old 01-30-2008, 06:26 PM
  #26
Jason4X4's Avatar
Another Question
Are the starters the same between the 3.0 and 3.4. They look the same, but want to verify.
Old 01-30-2008, 09:27 PM
  #27
RobD's Avatar
Similar, but a teeny bit different. I'm trying to remember how this went, so bear with me. If memory serves, the 3.4 starter has one of the mounting holes threaded and the bolt goes through the bellhousing. And if my memory serves, the bellhousing on your transmission is threaded as well, so you won't be able to run the bolt through both threaded holes. I bored the threads out of the starter and ran the bolt through it into the bellhousing.
If memory serves.
Old 01-31-2008, 04:07 AM
  #28
Jason4X4's Avatar
If memory serves.
well I already had the 3.4 starter in, but the 3.0 starter was rebuilt not too long ago, just wondering if the gears are gonna match to the flywheels.
Old 01-31-2008, 05:32 AM
  #29
Elvota's Avatar
I am useing the 3.0 starter on the 3.4 for a similiar reason.
No problems.
Old 01-31-2008, 02:05 PM
  #30
Cacustom's Avatar
man, you put that motor in super fast.
Old 01-31-2008, 02:45 PM
  #31
Lysmachia's Avatar
Glad to see you got another 3.4 Mile looks like it is in pretty good shape but seriously considering the rebuild.... for this reason.
Old 01-31-2008, 03:47 PM
  #32
Jason4X4's Avatar
Just got home with the new one, gonna go start putting it in..
Old 01-31-2008, 05:31 PM
  #33
RobD's Avatar
Good luck with this one. If you have any questions that I might be able to answer, let me know.
Old 01-31-2008, 06:41 PM
  #34
Jason4X4's Avatar
well, it took alot longer than expected to swap everything, this one came out of a taco, so we had to switch the pan, and plug the dip stick hole, along with the harness, t belt, and clutch, gonna go stab it and bolt it in and finish up tomorrow night.
And when we took the intake off the 1st 3.4, there is about a quarter inch of mud in 4 of the intake runners, I think we found a problem, I'm guessing bent rods.
Old 01-31-2008, 07:25 PM
  #35
Jason4X4's Avatar
Here's the new one
All 3 together
getting ready
And In Place, AGAIN
Here's what was in the runners on the 1st 3.4
Old 01-31-2008, 07:36 PM
  #36
Elvota's Avatar
Even though this swap has turned into a bit of a disaster... it's pretty impressive that you have already found and installed to 3.4 in less time than it takes most to just install one. Myself included.
What will you do with the "bad" 3.4? Is it worth rebuilding?
Old 01-31-2008, 07:37 PM
  #37
good to hear you got the new one in already and making some really good progress on this thing. Those last two pics are UGLY! Keep up the great work. you must be a really good friend to have!
Old 01-31-2008, 08:10 PM
  #38
Jason4X4's Avatar
Well, when we get some time, I'm gonna tear it down and see what is going on, depending on what I find, will decide it's fate.
thanks
Old 01-31-2008, 08:19 PM
  #39
rayl82's Avatar
Exclamation Hats Off!
Jason 4x4 is the best! i don't know were I'd be with out him, (probably over at elvota's place) ha ha j/k .. hats off to my friend Jason!
Old 01-31-2008, 08:28 PM
  #40
rayl82's Avatar
at a later date we may check the 1st engine to see if it's worth repairing i may use it in the rock buggy I'm building but for now its a paper weight. and if its no good it's a core but i still have that 3.slo sitting there i may through that in the buggy just till i blow it up.... but thats later. Elvota that lower hose part number you posted drops the neck two inches to far on mine had to find a different one at auto zone I'll post a part number later, are the radiators different? 89 4runner.
Quick Reply: Rayl82's 3.4 swap
