Oregon's Lone Wolf 3.4 swap
Old 08-20-2015, 06:01 PM
  #161
Rebel007's Avatar
It's been a long time !
Originally Posted by poleclimber63
Not sure if I read this right, are you swapping out a 3.0L for a 3.4L swap? This will require re-pinning.... What vehicle do you have? If you have, say, a 96 3.4L 4R, and you're dropping in a 2001 3.4L, really what you're doing is a long block replacement. All 3.4L long blocks are the same. Just unplug/ remove the wiring harness from the engine and tuck it under the wipers, un-bolt the PS pump and AC and strap them to the side. Remove the rad and alt. Remove the inside fender flaps (access to the mounts). Remove the TB and exhaust pipes and pull the engine. If the engine came from a 4R, then all you need to swap are the injectors (they changed the injectors in 99)... if its from a Tacoma I'm not sure what differences there are, in my case my engine was from a Van, so I unbolted all peripheral components from my old engine and bolted them onto the replacement. Done. No wiring required.
Thanks for your description it really helped! My mom has been sick so I am just now getting back to work on my truck. (98 Tacoma 3.4 v6 manual )). I have most everything disconnected or removed. I am down to the exhaust and transmission bolts. My question is " Do I have to remove the entire exhaust to get to the bolts on the transmission? I don't see any way around the cross member exhaust .
Last edited by Rebel007; 08-20-2015 at 06:03 PM. Reason: One more question, Are the 3.4 v6 engines that are posted on ebay that are imported from Japan good to use ?
LosPatosDelSur
23
03-12-2021 03:08 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
93toyoguy
08-02-2015 07:41 PM
94whiterunner
07-12-2015 07:15 PM
Quick Reply: Oregon's Lone Wolf 3.4 swap
