Need TPS help!
Old 06-07-2013, 12:26 PM
robwise's Avatar
Need TPS help!
Ok so I think I may have f***ed up a little.
History:
89 single cab
98 4runner 3.4 (auto donor)
96 tacoma 4x4 MT ecm & harness
Here is where I ran into trouble, As some of you may know the 98 4runner used a 3 pin TPS (top two pictures) and my harness called for a 4 pin TPS (lower 2 pics). I believed the pn was 89452-22080 for the 4 pin, so i ordered one... biy the way it connects to the throttle body is completely different!
If you look at the pictures the 3 pin connects to a flathead looking ens and my 4 pin does not.
Has any one experienced this??
I figure my options are:
A) re pin my harness to run the 3 pin, but i don't know what the forth wire does...
B) order another TPS because maybe i have the wrong part number?? anybody have that info?
C) get a different wirring hanses and ecm combo and re-wire my truck...
Old 06-07-2013, 12:28 PM
robwise's Avatar
picture 2
Old 06-07-2013, 12:30 PM
Team420's Avatar
I'd go with option B... lol
I do not have the part # tho.
robwise's Avatar
picture 3
Old 06-07-2013, 12:32 PM
robwise's Avatar
picture 4, sorry about the quad post. my computer was being difficult.
Old 06-07-2013, 12:50 PM
robwise's Avatar
Haha me either
I guess there is also option D) get a different throttle body
Old 06-08-2013, 09:45 AM
robwise's Avatar
Ok, so I think i figured this out, if anyone runs into this I think swapping throttle bodies will work.
Old 06-10-2013, 08:14 AM
aferg's Avatar
Yep, that is what i am doing, 89 Truck ~ 97 4Runner 3.4L ~ 95 T100 ECU and harness.
I just swapped the TB and am going to trick the ECU for the EGR Temp sensor... 2K resistor if I remember right...
A.
Old 06-10-2013, 08:21 AM
robwise's Avatar
Yeah that was my plan as well as far as the temp sensor. There are two mor sensors that I'm unsure of, one is right next to the egr and appear to be part of the same system, and another one is up by the front of the manifold and goes to a breather valve not used in the donor 4runner. Any ideas on what to do with these? Trick them as well? When I pulled my harness from the scrap yard I took all three of theses sensors too, I can post pics for clarification if needed.
Old 06-10-2013, 11:44 AM
aferg's Avatar
Sorry, no I don't know... My 95 T100 only has the one sensor (That I know about) I have not looked at any tacoma's...
A.
some drunk guy
08-03-2021 06:09 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
larrys93pickup
09-17-2015 07:05 PM
sanctfy
09-13-2015 06:33 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: Need TPS help!
