NEED Motor to Trans Mounting Help!!
#25
I used a breaker bar on the crank bolt. Having a buddy turn it makes the job go so much quicker. TIP: tighten each bolt to just snug down plus half a turn then go through each one again and tighten it to spec. I didnt do this the first time and was surprised to see the tc off center. Did it the second time and I could see it pull in line. I marked the first bolt with bright red nail polish. TIP: dont let your wife find dirt in her bright red nail polish.
#26
ok next question, I've been trying to sping the flexplate but the tc keeps spinning with it..I loosened up the motor to trans bolts it made it easier to spin but the tc still spins with it.
I hate to say it but is it a strong possibility the tc isn't seated all the way in and that's what's making it bind?..causing me to have to remove the motor once again?
WTB[PacNorWest]: w56 c manual trans with t-case and drivelin
89hilux1
07-19-2015 01:32 AM
the1998sr5
07-16-2015 06:20 AM
Poncho0206
07-10-2015 06:21 PM
