is my wiring correct? check it out..
Old 04-12-2012, 03:26 AM
JTonJuice's Avatar
can some someone please lay this out for me.
3.4 from a 97 4runner auto with 98 tacoma ecu
im using the 4runner auto harness it plugs into the ecu
goin in 91 3slo truck manual
heres what i got so far pls correct..
3.0
G-L= speed sensor
G-W= brake? there's 2 ?? help
W-G= SEL? help
Blue= + pump
Y-B=THA?
B-R=ignition 2 fat wire
B-R= skinny wire?
W-R= B+ efi
B-G= Batt
V- check engine light
G-Y= negative goes to COR?
G-W= indicator switch transfer position? help
B-W= A/C clutch? help
Y-Blue= oil pressure
Y-G-water temp
B- tach
G-Y indicator switch? help
B-O= help?
B-R=a/c idle up? help
Blue= help
Blue=help
R-W=help
3.4
B-R= IG2
Blue-r=to detection switch transfer neutral position L4? help
W-R=am2/ help?
R-G= to detection switch neutral position? help
G-B 4wd add to indicator switch? help
W-Blue= B+
G-Y= goes to fuel pump relay - ? help
G-W= brake? help
G-W= oil pressure? help
V-check engine light
B-W= Batt
W-B= clutch pedal
B-=tach
Old 04-12-2012, 03:39 PM
QuickSilver74's Avatar
i'll post up mine tonight. i had some of the same issues. i got the brakes working today havent dropped the engine in yet but i am fairly certain i have it mostly figured out
Old 04-12-2012, 06:42 PM
JTonJuice's Avatar
thanks quicksilver ill be waiting..
Old 04-17-2012, 02:11 PM
JTonJuice's Avatar
got it to fire up.. still need help with dash wiring..
http://youtu.be/MIMDfSUA1hc
Old 04-19-2012, 07:51 AM
vasinvictor's Avatar
Sound good, congrats. Looks like you still have a bit of work to do.
Old 04-20-2012, 12:20 PM
JTonJuice's Avatar
yeah sounds even better now i had plug wires crossed on that video. i installed all the belt s found out its not charging the battery im using 3.0 alt and harness just extended the power cable to the fuse box, got any idea what wrong im thinking alt.. truck wasn't running when i bought it thanks..
smthwsn357
05-01-2024 07:28 AM
Sleaker
08-26-2020 06:03 AM
Coreyr384
07-10-2015 11:13 AM
crashburnoveride
07-10-2015 06:39 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: is my wiring correct? check it out..
