Mounting OBDII port
Old 05-01-2012, 02:07 PM
anthony1's Avatar
Mounting OBDII port
Where do you guys mount the OBDII ports? how?...Thanks.
Old 05-02-2012, 04:48 AM
dntsdad's Avatar
I put mine in the glove box. Actually above the glove box there is a flat, vertical plastic area of plastic so it stick out straight to receive the plug from a scanner.
With the glove box closed, its hidden and open it to access.
Stock wires reach without having to extend them. Works perfect.
Old 05-02-2012, 05:04 AM
waskillywabbit's Avatar
Every one we've put in the "stock" location. That way anyone else has little clue that motor wasn't put in there by Toyota
:wabbit2:
Old 05-02-2012, 05:46 AM
vasinvictor's Avatar
Mine's stuffed back down in the kick panel to where I can pull it out the top if necessary. OBDII reader stays in glovebox at the ready.
Old 05-02-2012, 06:07 AM
Replicant's Avatar
I ran the wires across and put mine in the factory location as well, just screwed it in under the dash.
Old 05-03-2012, 07:39 PM
anthony1's Avatar
Got any pics of it?
I have the wire run under the steering wheel but I'm not sure where to put this thing so that when the plug is push and pull it won't pull it out over time.
Ronnyboy
02-11-2016 05:57 PM
sonorn67
09-19-2015 05:39 PM
anniesball
10
09-15-2015 05:41 PM
Boomer8404
09-10-2015 09:01 AM
old87yota
09-09-2015 12:39 PM
Quick Reply: Mounting OBDII port
