irab88 adds another liter: 22R-EC to 5VZ-FE
Old 03-11-2014, 09:09 AM
  #61
"G"
"G"'s Avatar
That's awesome, go flush your brake lines.
Old 03-11-2014, 05:49 PM
  #62
irab88's Avatar
Sweet, thanks for that pic. I guess it did motivate me, because I got home quickly and started back at it. I managed to pull the 3.4 and start clearing out stuff from the 2.4 engine bay. I got a lot done. I would have gotten on to more, but I had to make a quick run to lowes to get bolts to hold the 3.4 to the engine stand. M12x1.25, 80mm worked for me, McMaster Carr has them much cheaper, but I didn't feel like waiting
Old 03-11-2014, 05:50 PM
  #63
irab88's Avatar
last thing that was plugged into the main harness
disconnected the fuel. i used foam earplugs to block the passages
and then...
then i turned to the truck. i got a lot done, but i still have plenty to do
for pulling the header off, it wouldn't just slide over the studs. i used a stud-tool that i found (mostly by accident) on ebay. snug it down by hand, tighten the allen screw, then slowly back the stud out. it saved me from using pliers or welding anything to get them out, and it won't damage the threads if i need to put new studs in.
and done for the night
removed: radiator, intake, battery, fan, exhaust, throttle cable, (some) wiring, and heater lines.
left to remove: power steering, a/c, fuel, main harness, and transmission.
Old 03-12-2014, 09:25 AM
  #64
JBurt's Avatar
That last pic is great! Keep up the good work.
Old 03-13-2014, 07:05 AM
  #65
irab88's Avatar
thanks
after searching around for a bit, i've decided to make my 3.4 exhaust crossover like this. it combines the 2 pipes before the downpipe, so there should be more clearance between the firewall and head. also, i won't have to deal with trying to get the pipes out of that dual-pipe flange
Old 03-13-2014, 07:48 AM
  #66
ChefYota4x4's Avatar
Woohoooo! Kicking butt, congrats!
Old 03-13-2014, 08:20 AM
  #67
rattlewagon's Avatar
This is epic. Your truck is going to be the ultimate sleeper.
Old 03-13-2014, 08:29 AM
  #68
irab88's Avatar
hell yeah. especially with the muffler i'm thinking about. haven't picked an exact one yet, but i want it big and quiet
Old 03-13-2014, 10:07 AM
  #69
chukarhunt's Avatar
Just dropping in and checking out! looks great man. Sleepers are always fun.
Old 03-13-2014, 08:32 PM
  #70
JBurt's Avatar
That looks really good. Are you planning on doing a heat wrap or some other type of heat shield? I don't know what you're going to have close to your crossover pipe but I was just curious. Is the heat not as much of an issue with a manual tranny than it is with an auto?
Old 03-16-2014, 05:49 PM
  #71
irab88's Avatar
not sure on the heat issue
yesterday i got the 22r-e pulled. there are a lot more wires and cable bundles than on the 3.4
i should have done this to fix the timing chain guide
steering pump bracket was missing a bolt here on the timing cover. there was a lot of oil around there
i'll start selling parts off of it soon enough (headers, accessories, intake, valve cover, oil pan/pickup, etc)
Old 03-16-2014, 07:26 PM
  #72
uwabaseball's Avatar
Great thread. Got me excited bout my swap I'm in process of getting things together. I am a lil stumped on what I can get rid of in my engine bay for my 22re. I think I can just take out everything and put the 3.4 stuff in but not sure. Anyway good luck on ur swap can't wait to see the end
Old 03-17-2014, 03:23 AM
  #73
irab88's Avatar
You can take out everything that bolts to the engine. I still need to remove the a/c, power steering pump, exhaust system, and about an inch of dirt/oil/coolant that's caked on the frame.
Old 03-17-2014, 07:58 AM
  #74
irab88's Avatar
so, apparently this is becoming a popular swap. since i've started my own, i've seen about 3 or 4 other 22r to 5vz swaps.
anyway, this weather sucks massively. two days ago i had my sleeves rolled up. today:
Old 03-17-2014, 04:24 PM
  #75
Swimmerboy2112's Avatar
Wow that sucks! They were calling for snow up here but we dodged that bullet. Still 27* for a high today though.
Where is spring!?
Old 03-19-2014, 01:38 PM
  #76
irab88's Avatar
got my replacement parts. both shipped for under $50
Old 03-20-2014, 04:02 PM
  #77
irab88's Avatar
got some parts today, and loosened a bunch of bolts, drained the oil, and got the power steering pump pulled
i'm going to fab up my own lines here. hence the clean cut
Old 03-21-2014, 07:06 AM
  #78
irab88's Avatar
note: the power steering line that i cut (picture above) is steel
OD: 0.40"
wall: 0.075"
mcmaster pn: 9220K361 has an ID of 0.405", which should fit nicely over, and be able to weld up to create a new hardline. also, it's rated for 1,900 psi
Old 03-21-2014, 09:42 AM
  #79
Having a great time following this man! Hope it warms up for you!
Old 03-21-2014, 10:12 AM
  #80
RBX
RBX's Avatar
50* today. That's warm for here.
Quick Reply: irab88 adds another liter: 22R-EC to 5VZ-FE
