irab88 adds another liter: 22R-EC to 5VZ-FE
Old 02-19-2014, 05:33 PM
  #41
irab88's Avatar
got it, thanks. the link is in black
Old 02-23-2014, 08:53 AM
  #42
irab88's Avatar
Picked up the 4runner yesterday. Traffic was bad on the way up, and tolls grossed about $50, but the trip went very well
pics soon
Old 02-23-2014, 11:44 AM
  #43
irab88's Avatar
pulled out of brian's driveway
closer to home, needed gas (two tanks for the whole trip)
aaand into my driveway. to unload, I just set the 4runner's e-brake and drove forward
I wired the 4runner's tail lights into a trailer wiring harness for lights on the drive home. worked perfect
the ecu
and the 4runner in it's final position. tons of room to work on it
Old 02-23-2014, 01:33 PM
  #44
JBurt's Avatar
that's great. It hought Brian was going to keep the ecu for his swap.
when you part it out I'll take the cup holders if they work. I'm more interested to see your swap though.
When is the sas coming?
Old 02-23-2014, 02:15 PM
  #45
irab88's Avatar
he said he was, but he threw it in. he mentioned that he could find another one. also, I think there's a way to trick out the auto ecu to work as a many tranny
I won't be parting it out for a while as I want to start pulling out the stuff from the truck first. but I will keep that in mind
sas? next year, maybe? I'm going with a custom setup with leaf spring sliders and relocated forward a few inches
Old 02-23-2014, 02:54 PM
  #46
JBurt's Avatar
manny tranny made me laugh. I know of a few people who've kept their auto ecu
I'm glad you can get started. It will feel really good to get back behind the wheel of your truck.
Old 02-23-2014, 04:46 PM
  #47
RBX
RBX's Avatar
O2 bypass instead of URD
http://www.vfaq.com/mods/O2bypass.html
Glad to see you got the runner home.
Old 02-23-2014, 08:42 PM
  #48
Swimmerboy2112's Avatar
The donor is a 96, my 4Runner is a 97, i've heard of issues from swapping years of ECU's.
The only difference with having my auto ECU is that there will be a CEL for what the ECU thinks is a missing transmission.
Old 02-24-2014, 11:39 AM
  #49
irab88's Avatar
i forgot to post a picture of the most important part:
Old 03-04-2014, 11:00 AM
  #50
irab88's Avatar
less than 12 hours after i step off the plane, i go pick this up
and these
to lift the engines out. got them all cheap-ish on craigslist
also picked up the plywood to roll all this stuff around on
and some light! for the graveyard hours.
i won't be working on anything this weekend due to other commitments, but i will be starting to pull off the little things during the week
Old 03-08-2014, 05:32 PM
  #51
irab88's Avatar
started dissecting the 4runner today
need to replace this. the port broke off in the wreck. also, the charcoal canister was broken and leaking... well... charcoal. i'm going to be using the 4cyl canister anyway.
i need to disconnect the fuel lines, alternator plug, main harness, and mounts. then i can lift the engine out. then i'll start gutting the truck
Old 03-08-2014, 05:54 PM
  #52
Fossilized
Staff
dropzone's Avatar
getting there
I am sure you might find a few more broken odds and ends as you pull the motor.
your x cab is gonna be whole new animal
Old 03-08-2014, 06:22 PM
  #53
irab88's Avatar
i can't wait to slap the tube doors on and to power-slides through the round-a-bouts! the whole time i was wrenching today, someone was idling their hotrod, so i had some nice inspiration to keep at it.
if it wasn't for this city weather and my city schedule, i'd be almost done by now
Old 03-08-2014, 08:32 PM
  #54
RBX
RBX's Avatar
Excited to hear the butt dyno after this since a 4Runner is around 4200lbs. stock and your truck should be around 3500lbs.
Old 03-08-2014, 10:16 PM
  #55
irab88's Avatar
>cough< yeah, 3500...
last trip to the dump weighed in at 4100 (after dumping) smh
Old 03-09-2014, 08:03 AM
  #56
RBX
RBX's Avatar
Oh, I did a search and found the wrong weight evidently.
Old 03-09-2014, 09:55 AM
  #57
Nice! Get wrenchin on that bad boy!
Old 03-10-2014, 06:07 AM
  #58
irab88's Avatar
i just meant that i have probably added ~500 lbs of stuff to my rig, in the form of dual cases, larger tires, toolbox, brush guard, and all the little things
yup! today and tomorrow are supposed to be gorgeous, so i hope to be able to pull it out soon (so i can put it in the shed to work on once it gets cold on wednesday)
Old 03-10-2014, 07:59 AM
  #59
ChefYota4x4's Avatar
What's up buddy?!?!
Just dropping in slinging some support at you! Sorry I haven't been following, totally overwhelmed with the swap! Lol....
By the way, you may have added 500 pounds, but you're still probably a 500 Shy of a stock 2nd Gen 4 runner! ..... Anxious to see this happen! Best wishes to you all the way through this
Old 03-11-2014, 06:28 AM
  #60
2toys's Avatar
Here's a pic of my recently completed swap for inspiration haha. you are gonna love your runner a whole lot more when you're done. The only problem I've had with my swap is the leaditis in my right foot just can't seem to keep it outta the throttle. Seems like you can handle the wiring on your own but if you get stuck on anything let me know its all fresh on my mind.Name:  IMG_20140203_093951_471_zps742f4e3f.jpg
Quick Reply: irab88 adds another liter: 22R-EC to 5VZ-FE
