irab88 adds another liter: 22R-EC to 5VZ-FE
Old 02-07-2014, 01:37 PM
RBX
RBX's Avatar
Dam that was fast.
Old 02-07-2014, 02:05 PM
irab88's Avatar
brian had the truck for a good price, so i'll pick it up soon-ish
Old 02-07-2014, 05:50 PM
RBX
RBX's Avatar
Good for you man, I went and looked up the ad he had.
Old 02-13-2014, 03:16 PM
irab88's Avatar
my bellhousing came in, i'll pick it up from the po tomorrow
Old 02-13-2014, 03:30 PM
  #25
Swimmerboy2112's Avatar
Hey buddy, got all my parts pulled so the 4Runner is ready to be taken to it's new home.
Just gotta figure out how to get it out of my garage. lol
Old 02-13-2014, 07:56 PM
  #26
RBX
RBX's Avatar
A come-along and a trailer!
Old 02-13-2014, 08:15 PM
  #27
ChefYota4x4's Avatar
Sick!
Old 02-13-2014, 08:18 PM
  #28
BigBluePile's Avatar
Have fun!
Old 02-14-2014, 01:51 PM
  #29
irab88's Avatar
bellhousing came in
it fits the tranny, this should be the ticket for my swap
the shaft sticks out about 0.125" from the face of the bellhousing (i estimated)
drain at the bottom
vent at the top
hole that needs to be covered
"toyota 3.0 4runner 5-spd 94"
moved the toys and parked the truck where i'll do the swap
ready for the parts truck (hopefully i can pick it up next weekend. there was a huge snowstorm - 2 feet - where the runner is right now)
Old 02-14-2014, 02:53 PM
  #30
Awesome update with pictures! Lol. Super excited for you man! I'm sure it will be one of the cleanest swaps, at least electrically and I'm sure in many other ways, in much of yotatech! I drove around with Johnny boy the other day and his heavier 2nd Gen 4 runner was so quick off the line! Definitely got me excited!
Old 02-14-2014, 03:30 PM
  #31
aztoyman's Avatar
Looks like you are missing a dowel on the bell housing. Make sure you have them both. Should swap from the other one. Make sure one isn't stuck in the trans or you might crack something when you tighten the bolts down.
There is a rubber vent thing for the hole in the top.
Snow sucks! Unless you're playing in it. 94 degrees in Az today. Summer's going to suck though.
Glad you found a donor. Your swap will go so much smoother.
Old 02-16-2014, 04:58 AM
  #32
irab88's Avatar
thanks. i took that dowel out as i already have both in the spare trans. i'll probably be ordering a bunch of hardware for that, seeing as i don't have a v6 with bolts already there.
since i'm doing mild trans tunnel work, i may also add a top hole for ease of transmission removal (for the two top bolts). just a thought for now
and i was looking through the wiring diagrams for both the truck and 4runner, and it doesn't look that terrible. since i have the donor truck, it looks like the only things i'll need to splice are the fuel pump and dash. not much else, if anything. for the alternator, i'll use the same 1-wire configuration as before.
Old 02-16-2014, 05:17 AM
  #33
irab88's Avatar
re-read, found my answer
Old 02-16-2014, 07:48 AM
  #34
RBX
RBX's Avatar
That's great, but I read the dash is 40% of eye wiring.
Good luck
Old 02-16-2014, 09:12 AM
  #35
irab88's Avatar
fuel gauge, oil pressure, water temperature, battery, and warning lights are a direct swap
the things that make it tricky are the speedo and tach
plus, I do wiring for fun
Old 02-16-2014, 01:06 PM
  #36
RBX
RBX's Avatar
I know wiring isn't an issue for you.
Direct swap? You mean connectors are the same?
Old 02-16-2014, 01:25 PM
  #37
irab88's Avatar
nah, just a direct connection. as in wire-to-wire, no fancy converting or adapting
Old 02-19-2014, 11:48 AM
  #38
RBX
RBX's Avatar
been reading lots of 3.4 swap threads.
be sure to address the O2 sensor issue on bank #2 CEL PO420. Seems aftermarket CATs throw codes after a few thousand miles. Popular solution is the URDUSA O2 Simulator
I've also read that the 5VZ power steering pumps burn up quicker, some say it is due to the rack and pinion high pressure strain. Some guys convert a 3VZ P/S pump to work on the 5VZ with a pulley change.
Very desired year is the 99 4Runner 5VZ as Toyota fixed an issue with the TRD Supercharger in the ECU from previous years.
Nice thing is that the 5VZ uses OBDII, so you can monitor the engine realtime with software or ScanGauge
Tremendous thread by Mt.Goat 3.4 Swap Started
He had a crack in his collector, but I am not sure what happened.
I'm sure you know this stuff already, just thought I'd increase my post count for the day.
Old 02-19-2014, 04:52 PM
  #39
irab88's Avatar
too bad most of his pictures are down
Old 02-19-2014, 04:53 PM
  #40
RBX
RBX's Avatar
go to the first page and there is a link to all, if not, most of them.
Quick Reply: irab88 adds another liter: 22R-EC to 5VZ-FE
