Which headers for the 3.4 swap?
Old 01-12-2011, 05:03 PM
kcorpetti's Avatar
Yeah im asking about headers for a 3.4 swap. I have the engine out, so I just need to know which ones fit...!
Old 01-12-2011, 05:07 PM
Texas_Ace's Avatar
Ah, can't tell you that one, i know the doug thorleys fit like a glove in a 3rd gen. Not sure about a swap. With the engine out the install would be easy as well.
Old 01-12-2011, 05:48 PM
PismoJoe's Avatar
JBA makes a set for them, I would bolt it on before dropping the engine in. There is a crossover bolt that is hard to get to with the engine installed.
Old 01-12-2011, 07:27 PM
kcorpetti's Avatar
You mean a set for the 3.4 swapped engines?
Old 01-12-2011, 08:06 PM
  #25
PismoJoe's Avatar
I mean a set for any 3.4l 5vz-fe, so yes if you swap one into whatever vehicle....
Old 01-12-2011, 08:11 PM
  #26
camo31_10.50's Avatar
it's not the motor Joe, it's the clearance of everything AROUND the motor..
Old 01-12-2011, 08:21 PM
  #27
totally a bro
Staff
vital22re's Avatar
title edited and moved to 3.4 swaps. You're taking a motor that the exhuast was designed to drop on the passenger side and put in rig that drops on the driver side. The clutch slave cylinder on 5spds will be an issue. Maybe on an auto it will be okay.
Old 01-12-2011, 09:03 PM
  #28
PismoJoe's Avatar
Ohhh got it haha I thought he just wanted a brand
Old 01-13-2011, 04:07 AM
  #29
kcorpetti's Avatar
Thanks for the aclaration, vital22re.
Yeah, im looking for headers that would work on a swapped 3.4. What do you guys think of custom-built ones?
Old 01-13-2011, 04:07 PM
  #30
S.C.YoTa's Avatar
Originally Posted by vital22re
pretty much true... headers will not just ... bolt on. You will have clearance issues on the pass side because of the clutch slave cylinder and shift fork.
the exact problems i had on mine thats why i sold it . i had the obx brand.
Old 01-13-2011, 09:34 PM
  #31
aa1911's Avatar
I love my doug thorley shorties, pricey and won't give much gains by themselves but are a beautiful combo with a SC... as for stuffing in a 2nd gen... mmm... my same dilema here this summer when I do my 3.4 swap (+SC)... don't think they will fit according to what I read from others' experience...
The stock headers will flow OK w/ a SC but performance headers do give better flow thru the engine, increases volumetric efficiency... they (in theory anyway) 'pull' exhaust gases from the cylinders as they fire... they do sound beautiful also, not too loud but still robust.
I would be curious to see if anyone can make these aftermarket headers fit in the 2nd gen 3.4 swap, seems like a near impossible task... does anyone know if a custom crossover pipe will A) fit reasonably, B) retain the headers' full capabilities??
Old 01-13-2011, 09:39 PM
  #32
aa1911's Avatar
If you can (or know a shop that can) fab up some custom headers, you don't need very large diameter pipes but just equal length primary tubes, would be sweet if someone would start making some "3.4 swap" shorty headers to work around the clearance issue...
Old 01-14-2011, 08:29 AM
  #33
Texas_Ace's Avatar
The doug thorley headers were dyno proven to make 15hp more on an NA truck, the dyno is floating around someplace. Never saw the numbers for a SC truck but they would be higher.
Old 01-14-2011, 09:44 AM
  #34
The hardest part of pulling my headers off right now is removing my steering shaft and that's only cause mine is wedged in there from making it about 1/16" too long. Other then that I can pull the headers on and off my truck in nothing flat! I'm guessing the inner wheel well or something is what you guys fight with that makes it so difficult? I don't have that so access to them is a breeze thru the wheel well.
Also, my headers clear the slave and fork on the pass side with no issues. I did wrap them with header wrap to try and keep the heat down around where the rubber boot for the fork is and the boot on the push rod of the slave cylinder though.
Fitment wise, I did cut the outlet on the pass side and rotated it a little to index it away from my frame rail cause stock it rested right against the frame. On the drvr side I had to put a "custom dent" in the forward tube to clear my steering shaft but I think that's cause my truck is built around a 3" body lift so the steering shaft isn't running thru where the stock location would be.
Overall though the headers were by far one of the eaiser parts of the swap... I do still need to take it to the exhaust shop to have a "Y" pipe built to connect the headers to my tail pipe though.
Old 01-14-2011, 07:42 PM
  #35
theMonch's Avatar
I have the Downey's on my 3.4 1st gen S/C swap for about 7 months now. I absolutely love the sound and they make great power. I went straight from the 3.0 slow mildly modded to the 3.4 S/C headers w/ URD 7th injector, so I don't know if they made adiffernce over the manifold, but I can tell you they sound very intimidating even though they go back to 1 pipe at the converter. You can read all about the clearancing that I had to do (not much) to get them in there in my build thread. I also had a custom 2 into 1 crossover custom made with an integrated HP cat and had 2 1/2 stainless from there back with the old 3.0 setup that I kept. There is a vid in my build thread in my sig that has them running open right after I got the swap up and running.
Old 01-14-2011, 07:53 PM
  #36
MaK92-4RnR's Avatar
alrighty... well... lets make a discussion about what the headers HIT when you put the 3.4 into a 1st, 2nd and 3rd gen truck and 1st and 2nd gen 4runner? because I was told that the downey's and Doug thorleys dont have a fitment issue when they are used on a 3.4 swap.
Old 01-14-2011, 08:37 PM
  #37
totally a bro
Staff
vital22re's Avatar
then add 2wd vs 4wd
Old 01-15-2011, 02:29 PM
  #38
theMonch's Avatar
I can only speak for my 1st gen 4R experience, but here is what I experienced. Again, it is a 88 with a 97 3.4.
The drivers side comes incredibly close to the steering shaft. I had to remove the plastic cover that protects the joint. My Downey's had the provision for the EGR option so I had to cut off that flange and weld up the resulting hole.
I had to fabricate a custom alternator lower bracket so the alternator can be run imboard more towards the center of the engine. This could be because I an running a high AMP NWR alternator, but it looks to be not that much bigger than the stock 3.4.
I had to cut the heat shield that protects the torsion bar mount and upper control arm bushings. I had to take out about a 2" x 4" section.
I had to tweak the heat shield that protects the firewall down by where the firewall wraps under the truck.
On the passenger side I had to tweak the fuel hard line coils toward the frame a little to get them out of the way. There was also a heat shield on these that I had to remove altogether.
The passenger header dumps right next to the slave cylinder in a 5-speed application, so I could not have flanges mounted to the headers. Instead I used band style exhaust clamps and slip on joints to the headers. I have had no leaks so far with 7 months and 7k miles.
Old 01-17-2011, 06:28 AM
  #39
'89 2wd pickup. 3" body lift
Mine is bare minimum up front though. No torsions, no inner wheel well, etc...
Drvr side hit steering shaft and also a heat shield.
Pass side hit fuel line and rested right against the frame rail.
I moved, cut, removed, modified, etc to clear what was needed...
Old 01-17-2011, 05:15 PM
  #40
UKrunner's Avatar
I have stock manifolds ported slightly and port matched to custom 2 inch dual down pipes that "y" under the transmission bell housing. These then join a 2 to 1 collector and run down the same path as the stock 3.0 exhaust. All I have is the single stock 3.0 muffler - no cats.
Quick Reply: Which headers for the 3.4 swap?
