Build your own 3.4 crossover pipe
Old 05-13-2013, 12:56 PM
  #81
NytWolf's Avatar
Originally Posted by Sas954unner
Although not exactly the same design, that looks functionally too similar to the 3VZ crossover to me. Read that as a hot cylinder 6. In reality, I wouldn't know how well it would function, but I would prefer a Y-pipe joining the left and right cylinder banks at a lower location. Or at least angle the pipe coming from the passenger's side back more. That is, the joint shouldn't be at a 90 degree angle, but more of a 45 degrees downwards, so the exhaust is less likely to back up into cylinder 6.
Old 05-13-2013, 01:15 PM
  #82
totally a bro
Staff
vital22re's Avatar
Not a good idea. It does look too much like the 3.0 style. If there was more of an angle from the passenger bank to "direct" the flow out. Not back in.
Old 05-13-2013, 07:35 PM
  #83
Sas954unner's Avatar
I know the angle is a little pitched in but I used extremely large exhaust tubing and restricted the hole a bit where it dumps in by using a hole saw that was only as large as the diameter where it exits the exhaust manifold flange. Will that make te hot cylinder situation any better or should I start from scratch?
Old 05-14-2013, 04:14 AM
  #84
What if I weld a flap inside the pipe to divert the flow down instead of against the other sides exhaust?
Old 05-14-2013, 07:03 AM
  #85
NytWolf's Avatar
That would work with the diversion, but it would also impede flow. It's best to just get a Y-pipe. I've seen them sold at auto parts stores too.
Old 05-14-2013, 07:13 AM
  #86
I welded this thing nice and tight to the block and it came out just like I wanted it theres no way I'm going to cut this thing all apart hunt down more mandrel bent pipe and a y connector when I could just cut a flap of metal and fit it in so it takes up no more than half the pipe.
Thanks for the heads up on that hot cylinder situation though!
Hopefully diverting the flow a bit will help
Old 05-15-2013, 02:08 AM
  #87
Well after sleeping on it, I've decided you guys are right and I'd rather make this right before I get the engine in the truck so today I'm buying some more u bends and I'm going to start from scratch and make this next one Y together instead of T-Ing together. I'm stubborn as all hell but you guys are 110% right
And I can't deny it,
Old 05-15-2013, 07:00 AM
  #88
NytWolf's Avatar
Just wanting to help out another Yotatech'er.
Old 05-30-2013, 03:55 AM
  #89
Ok I finished up my wiring harness now it's back to fixing this damn crossover pipe so I can drop the engine in here is a side by side comparison of the first one I attempted and my new one I'm building
Old 05-30-2013, 03:39 PM
  #90
NytWolf's Avatar
Nice! Much better than the before pic.
Old 06-01-2013, 03:31 PM
  #91
All done!
Old 06-01-2013, 04:21 PM
  #92
Clearance
Old 06-01-2013, 04:23 PM
  #93
Another
Old 06-01-2013, 04:25 PM
  #94
Old 06-01-2013, 04:33 PM
  #95
Before and after
Old 06-01-2013, 04:35 PM
  #96
Thanks guys for the advice! Definitely saved me alot of future headache by giving it a little more effort now. I appreciate the help!
Old 08-04-2013, 02:20 PM
  #97
mt_goat's Avatar
Much better!
Old 08-24-2013, 09:48 PM
  #98
Jason4X4's Avatar
Rayl82 called me up and told me the pipe or weld broke on the crossover pipe, decided easiest route was pull trans, do a clutch while it is out, and pull pipe from bottom.
drivers head, pipe just off manifold broke just past the weld.
welded it back together, you can see the new weld just above the old weld
added some support so it can't happen again
got to thinking that he put a doubler in awhile back, and I think the mount has too much flex, and it was flexing the exhaust too much, so I told him to chain the mount, and ad more hangers, just in case.
and a current shot of the truck
Old 08-24-2013, 09:49 PM
  #99
Jason4X4's Avatar
whoops, looks like you will have to wait until the first to see the pictures, sorry.
Old 08-24-2013, 10:27 PM
  #100
totally a bro
Staff
vital22re's Avatar
You need that flex joint between the heads, Some people have even been adding them just after the bend under the body...
Quick Reply: Build your own 3.4 crossover pipe
