bellhousing help!
Old 12-13-2012, 07:32 PM
Belize Off Road Team's Avatar
bellhousing help!
it seems that the bellhousing from the 97 V6 auto 4x4 has a different bellhousing to the auto on my 93 4x4 pickup. i was under the impression that bellhousings might be shaped differently but the bolt holes would match.
is there a reason or are they all different just require something to make them work?
example, the bottom bolts on the 97 auto bellhousing seem to bolt from front to back rather then back to front like the 93, so the threads wont work the way they should.
Need HELP ASAP! removing 3.4 tomorrow and need to know before i do this.
Old 12-13-2012, 08:31 PM
bump my original less noob question.
Old 12-13-2012, 09:45 PM
Bump!
Old 12-14-2012, 01:01 AM
totally a bro
Staff
vital22re's Avatar
starter bolts up differently. On the manual transmissions the clutch slave in on the passenger side. That 3.4 transmission is designed with the idea that the exhuast will be routed on the passenger side. Your 3.0 trans will bolt up to the 3.4 just fine.
beebeeri000
10-02-2015 10:42 PM
viesail
09-21-2015 06:00 AM
mizombie
08-25-2015 06:28 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Quick Reply: bellhousing help!
