Anthony's 3.4 swap
Old 07-01-2011, 12:10 AM
anthony1's Avatar
Anthony's 3.4 swap
6/27/2011 After years of dependable service of the 3.0 engine, it has finally blown the infamous head gasket. The removal of the 3.0 has begun.
This process will be as fast as I can spare the time to do as this is not my only transportation.
Just to keep a log of how much this is costing me and others to prepare funding for their own swap project.
1996 T100 2wd 3.4 engine, intake, ECU, OBDII connector.................1450.00
Toyonlyswap crossover mods to change exhaust outpout to DR side.....195.00
Exhaust pipe after cross over pipe.............................................. ....100.00
Clutch kit............................................... .....................................225.00
Engine hoist rental (3x).............................................. ................... 81.00
Spark plug wires............................................. ............................. .70.00
Spark plugs............................................. .....................................40.00
Fly wheel resurface......................................... ...............................40.00
Timing belt kit ( belt, water pump, two tensioner bearings )................575.00
K&N air filter kit .................................................. .........................200.00
MAF............................................... ...............................................50. 00
O2 sensors........................................... ........................................215.00
Custom exhaust with CA catalytic converter......................................400 .00
95 2WD manual ECU............................................... .......................150.00
4.88 rear ring & pinion F & R................................................. ..................700.00
CA referee........................................... ..............................................8.25
etc...
So far, I've removed the radiator, wire harness from computer, exhaust from where the two sides meet and joined with three nuts. I've also removed the battery, intake pipes from the throttle body.
I'll be looking for a 3.4 engine at junk yards. I'm looking for a 3.4 engine from manual trans. I also plan to add a header while I'm at it.
Here's some pics to get started. I do have some advantages because I have 2" body lift and SAS. I have more room to work. Ex. I can get the top bolt of the transmission out easily. I can get underneath and side to loosen the AC brackets.
Old 07-01-2011, 12:16 AM
anthony1's Avatar
Here's the pic of the transmission bolt with 2: body lift.
Old 07-01-2011, 04:26 AM
waskillywabbit's Avatar
Buy a whole donor vehicle. You will be thankful you did. It will save you a ton of headaches.
:wabbit2:
Old 07-01-2011, 06:35 AM
anthony1's Avatar
I'd love to get a whole vehicle but I don't have room to park a vehicular caucus on my drive way which is in front of the house. Besides, my neighbors will not look at me kindly. There are bunch of resources for parts within about 10 mile radius and I don't live in a bad neighborhood either. That's just how it is in some parts of So. CA.
I also have you guys....
Old 07-01-2011, 07:00 AM
calipatient's Avatar
I used a place in Sacramento, Toyota Truck & SUV, who cuts great deals on swaps... sold me everything I need... $1900 after taxes. Ask for Alex. They ship nationwide or if I were you I would take a drive up and make sure you get everything you need. Just a thought!
Old 07-13-2011, 11:47 AM
timmJ's Avatar
Don't use Toyota Truck and SUV
I have been in there several times while doing my swap and everytime they tried to upsell something that was listed for much much less on carpart.com. Maybe it was just my experience but I thought they were just out to screw you. What ever you do, make sure you use a reputable place or check the engine extensively.. I pieced mine but I was able to find two places that most everything I needed. I also did a auto to manual swap at the same time. I ref it on monday and I can't wait. Good luck
Old 07-13-2011, 12:09 PM
Everyone has an opinion. I was actually there yesterday, a year after i purchased everything and well beyond my 60 day warranty. I didnt have the correct ecu and wire harness. He let me take a matching ecu and harness with the promise to ship the incorrect ones back to him. (I live 3 hours south of Sacramento) Also gave me a free mass air flow sensor since it changed in 99 to the drop in style. I walked out paying $22 for the last couple parts I needed. Worked out great for me!
I also did the auto to manual swap and got all the parts from the same place for about $350 including transmission. Again, no complaints!
I can understand them trying to make a few bucks... they tried the same tactics and once I told him the place around the corner would do he cheaper he matched the price no questions asked.
Did you use drivers side drop with the exhaust?
Good luck with the ref! Post back with the results!
Old 07-13-2011, 10:13 PM
anthony1's Avatar
They're a little far for me. I'm in So. Cal.
I've been talking to Cal Mini Truck in Montclair. They quoted me 1650 for engine, ecu, harness, OBDII conn., AFM... and $45 to deliver.
I've been sick with Bronchitis so I haven't done much to it.
Old 07-14-2011, 10:27 AM
Sounds like a good deal to me. Make sure harness and ecu match, that was my problem.
Old 07-16-2011, 12:24 PM
anthony1's Avatar
Cal Mini truck, one of the largest junkyard for Toyota trucks. They can't find the wiring for manual trans. I'm gonna go with the automatic engine out of 96 T100 with 67K miles. I'll have to deal with the wiring later. I'm getting it with manual computer and AFM, air cleaner box, OBDII connector...1450 +tx delivered to my house.
Old 07-20-2011, 10:58 AM
anthony1's Avatar
My 3.4 engine got delivered this morning.
Old 07-20-2011, 10:59 AM
anthony1's Avatar
The 96 T100 automatic wiring harness fit the 97 Tacoma ECU perfectly.
Old 07-20-2011, 11:00 AM
anthony1's Avatar
Here's the label for the ECU.
Old 07-20-2011, 11:56 AM
hamish_18's Avatar
why does it say 4x2 m/t? if it's suppose to be an auto ecu? It's not an m/t for 96 or 97 because that uses 2 row plugs. Maybe I am just not seeing it right?
Old 07-20-2011, 11:59 AM
hamish_18's Avatar
I really like how the t100 wiring harness runs to the driver's side. You are not going to have any problem with length of wires!! So lucky!!
Old 07-20-2011, 01:11 PM
anthony1's Avatar
I uploaded the same picture twice. It's good now.
yeah, I m glad I got the T100 engine. i don't have to mess with the oil pan swap.
The ECU is from manual trans 97 Tacoma truck.
Old 07-21-2011, 03:15 PM
anthony1's Avatar
I think eventhough the engine wiring harness from 96T100 2WD auto plugs into 97-98T100 2WD manual, The pins are probably different. I'm having the Toyota mech. at the dealer look up both wiring diagrams for me. I hop to have the answer in a few days.
In the mean time, I have the wiring diagram for the 96T100 2WD.
Anyone here has the wiring diagram for 97T100 2wd manual?
Old 07-22-2011, 08:04 AM
NIGHTCRAWLER541's Avatar
Your ECM part number says its is from a 1998 T100, FYI
Old 07-22-2011, 12:27 PM
You gotta love those salvage yards! They say one things and it turns out to be another!
At least someone was able to look it up for you.
I broke down and called Cliff at toyonlyswaps.com, as I was missing a few plugs needed. After talking to him for a few I ended up deciding to ship everything to them and let them build the harness. Glad I did... I'll have it back in 2 weeks ready to roll!
I would hit TIS up for $15 and get everything from 96-98/99? T100 so you have them all.
Old 07-22-2011, 02:50 PM
anthony1's Avatar
Thanks for the replies. Apparently, in 98, There were three or different manual ECU's according to Toyodiy.com My ECU was used for like a month or something. I think it's gonna be hard to find the wiring diagram. I'm hoping the ECU they end up using the longest which is 89661-34352 has the same wiring configuration.
I think I have all the plugs. I still need the intake box....or I'll just do the open air kit.
Quick Reply: Anthony's 3.4 swap
