88 4runner 3.4l swap
Old 05-20-2013, 11:23 AM
  #81
Austin Marr's Avatar
Originally Posted by Moto260
Ya, I would have liked to run a bigger wire but stuck with the 8g to the fuse box. No breaker. Starter trigger wire is ran through the firewall. I feel that my engine is sitting "off" because my engine mounts so I think I'm gonna get the right ones next opportunity. My fan rubs real bad on my fan shroud.
Not a bad idea. even if they "work" doesn't necessarily mean it'll "work" lol get what im sayin?
Old 06-05-2013, 07:46 PM
  #82
Moto260's Avatar
What's up everyone. Haven't been on here in a while. Fortunately I'm back to work. I'm a laborer I'm the union so I work long days. 10-12 hours. Hard for me to get spare time with my truck but I've been going at it every opportunity I get.
Got the right engine mounts, lifted the engine with tranny and swapped them out. Didn't change anything with the rubbing on my fan shroud but ill shave a little off, no biggy.
I got a different R134 A/c compressor and mounted it. My a/c line screws don't line up though >.< ill try to figure that out later. At least it's on.
My Engine wiring harness it routed correctly, (I believe). Heat taped everywhere around my exhaust. Most everything is plugged in aside from a few wires that feed to the drivers side of the tranny. A little lost on those. I got my conversion harness from ORS. And started with the routing of that. Everything in my cab is done except a place for a body ground on my drivers side. OBD is mounted, ECU is all plugged in, same with body harness. Routed through firewall, now i just need to do some soldering. I don't know where my reverse light switch wire is that I have to solder my ORS harness to. Probably need to buy a wiring diagram.
I can't seem to find a picture or guide on how to route my heater hoses. I can see on a 3.4l where they go but I'm not sure if that's the same place as I need mine routed. Any help on that or a picture would be awesome. Hoping my 3.0 hoses will work
Thanks everyone. Fun project. Getting close.
Old 06-06-2013, 08:13 AM
  #83
I'll try and get you a picture later this evening if someone doesn't beat me to it but I re-used my 3.0 hoses. Good progress! happy to help another union man! Im a union Low Voltage Electrician out of IBEW.
Also can help with depicting which connector does what with your trans harness if you can post pic's of each connector seperately
Old 06-06-2013, 05:59 PM
  #84
Moto260's Avatar
Good man. Good man.. Your out of sac right? Local 340?
And that'd help me out a lot. Ill try to get some pics of those wires up tomorrow night
Old 06-07-2013, 10:54 AM
  #85
Haha no Edmonds, Washington. My home local 191 our of Everett. Sorry about no pic's so busy after work I didn't have time to think about other stufff. I'll get you the pics this weekend
Old 06-07-2013, 12:02 PM
  #86
Moto260's Avatar
Hah I was way off there. Anyways no rush man I appreciate it.
Old 06-08-2013, 12:00 PM
  #87
Moto260's Avatar
Austin when I asked about my tranny plugs you said "transmission harness". I didn't get one of those I don't think. :-P probably my problem but ill post some pics of those plugs I'm having trouble with
Old 06-10-2013, 05:34 AM
  #88
Well its called your transmission harness but its tied into your engine harness already so I think you should already have every connector you need regardless. and i think that ORS should have provided wires for it. If they dont have connectors you can just cut the ones off your 3VZ and solder them onto the harness that ORS gave you but I bet you've got them already. No pics yet, sorry. Worked literally all weekend
Old 06-10-2013, 03:06 PM
  #89
Moto260's Avatar
Old 06-10-2013, 03:08 PM
  #90
Moto260's Avatar
That's where the engine harness feeds out by my tranny. Guess that's what you're saying is the transmission harness.
Here's my wires hanging that im lost on.
Old 06-10-2013, 03:09 PM
  #91
Moto260's Avatar
And here's the plugs closer up.
Old 06-10-2013, 03:10 PM
  #92
Moto260's Avatar
Old 06-10-2013, 03:20 PM
  #93
Moto260's Avatar
I got this harness when I bought the engine and engine harness. I think it's the 3.4l harness that feeds to your drivers side kick panel and out through fender well by new battery placement. Don't think I need it, but I'm curious about it cause it has two light bulbs on it. Maybe for the rear or front and I thought tranny harness because it has a Uhaul trailer harness wired around it. Yet none of the plugs match up to my engine harness(at least by my transmission). Name:  DFED918F-0421-47A8-8DBD-3A1D605FA3DB-322-000000215D9B2D41_zps6b387a05.jpg
It's got this boot on the end, and these two main plugs got a ton of gunk in them. I don't want to use it just by the look of it so hoping its just trash. Name:  4CE037BF-C1E0-4CE3-8AFB-44DA31534A6E-322-000000214BEE4EF9_zps92906e24.jpg
Old 06-11-2013, 06:02 AM
  #94
K the pic with the grommet. That harness I THINK is irrelevant. Dont trash it till your all done. Those connectors on your harness that drops down by the exhaust are the connectors as follows from longest to shortest: longest, looks like a VSS (vehicle speed sensor 3 pin) connector. the next one up looks like your t-case connector that detects your 4wd and turns on the indicator light on the dash. the next two that look identical that you are holding, one is for your reverse light's, and one plugs into the side of the tran's (forget what its for lol). and that shortest one that has 4 pins is your down flow O2 sensor which if you havent already will need to be added to your down pipe (as seen in my swap thread).
Also, I remember before you started a dedicated 3.4 swap thread we were discussing in another thread if you had a electronic speed sensor (VSS) and i had you take a picture of your t-case for me to see if you have a VSS....Do you remember that? or maybe it wasn't even you but i need to see a pic of the top of your t-case where there is any connector plug in's in it if that makes sense.
Old 06-11-2013, 06:43 PM
  #95
Moto260's Avatar
Ya that was me. Now that I look at it more. Possible I had takin a picture of the wrong thing. Here's more pics of everything
Old 06-11-2013, 06:51 PM
  #96
Moto260's Avatar
Back of transfer case drivers side Name:  DE70E556-5FA8-44B3-AF16-1CD43BEC369C-119-000000608D03C86B_zpsb20ba410.jpg
Passenger side back of tcase. (Thatis what I un-screwed in the old thread. its cable driven) Name:  EA513121-0C49-4F96-9C7D-66CEABD4AB81-119-0000006093151840_zps134c770a.jpg
This is on top of my tcase. Two wires and a plug coming offName:  6C4D5B57-D25C-46DE-B67E-51FDBC09D962-119-00000060984C881B_zps9c3a0d4e.jpg
Size:  54.2 KB same off top of my tcase Name:  CBEB7F87-1E44-497C-A261-21F22D894F76-119-000000609F1A1CC6_zps0cbbf02d.jpg
This is the only plug I see coming off of my transmission.Name:  C5F413D0-618D-477C-B249-9B76E16177DE-119-00000060AEE9694A_zpscde88faf.jpg
I thought these two plugs t case and transmission plugged into each other but they're different colors so I'm wrong Name:  303B1C65-5E67-4708-B0CF-E36ED475A8A8-119-00000060B983BA13_zpsf76b4f4c.jpg
And here's my 1 o2 sensor. I pulled off my exhaust and only have the down pipe that connects to my crossover. It has an o2 in it with a plug coming out for before my cat.
Old 06-11-2013, 06:56 PM
  #97
Moto260's Avatar
Short seasons in tahoe so long hours at work. But this weekend ill be putting a lot of time in. So hoping I can complete wiring finish heater hoses, get my intake manifold back on with cold air intake, and hopefully ill be pretty close.
Thanks for all the help.
Old 06-12-2013, 06:26 AM
  #98
Ya man. so it looks to me that you have all the connectors accounted for you need on your drivetrain harness and on your t case and transmission. the only thing though is that VSS that came on your drivetrain harness. I dont think you will be using that but dont lop it off. You probably wont be using that since you've got a cable driven speed sensor. And I understand the busy at work thing. I had to work late last night till like 11 and obviously couldn't get out to my truck in time to take pictures but i will send you them lol. did you order wiring diagrams? you cant just go color for color. what i did before doing any wiring is taped each set of wires that went with each connector and labeled the tape what connector they came from. Im STILL working out some wiring issues myself. Figuring out the OBD2 wiring, SMH so frustrating sometimes. And it sounds like i have a mis-fire which it just started doing intermittently (or however the hell you spell that word). Just can't find time between work, up keep on the yard and everything on the house and my honey do list....
Old 06-12-2013, 11:26 AM
  #99
Moto260's Avatar
Ya that sounds rough. Luckily I got the conversion harness from ORS so it simplified a ton of this for me, I'm just no good with wiring haha. There's a few wires to solder off of my ORS harness like 4wd indicator and reverse lights I'm wondering if those just get spliced on and I don't worry about my tranny harness. Or if I just splice directly from my tranny harness to those plugs I took pictures of. Or if I splice the connectors off of my 3vz harness to my tranny harness (5vz)
Old 06-12-2013, 06:47 PM
  #100
JasonYota's Avatar
Looking at the pics you posted about the trans, those plugs go into the trans of the donor. Do you still have the stock trans harness the was on your truck? All you have to do is splice the old plugs into the newer harness. Should only be four wires for the trans harness.(Since you have a mechanical speedometer)Plus the wires for the O2's. Two for the transfer case, and two for the reverse lights which should run up and you need to splice into your trucks body harness.
Quick Reply: 88 4runner 3.4l swap
