5 speeds
Did my swap but was an auto the auto also ˟˟˟˟ the bed....so I'm going to change it to a manual! Kinda didn't read much that didn't pertain to auto!
One is slightly longer if I remember correctly as well but I cannot remember which is longer.
The shifters are not interchangeable either.
I believe the gears are the same or at least similar enough to not be noticeable.
I bought all 3.4 clutch components when i installed the 3.4 R150 and kept it all when I switched back to the 3.0 R150. They are interchangeable. You will have to drill out a starter mount hole if using the 3.0 starter on the 3.4 bell housing.
I have ran both in my swap.
129Creepin
08-05-2015 10:12 PM
