3rz-5vz swap
Old 09-20-2010, 08:59 PM
85flopped's Avatar
3rz-5vz swap
Swap is mostly complete, truck starts and runs just need some info hopefully.
1-coolant gauge reads incorrectly (I hope) fire it up reads nothing.....idles for about 2min and gauge is pegged. full of coolant and bleed. guessing i need to swap sensors from the 4banger to v6?
2-tach reads really messed up. I am hoping I can just put some sort of a resistor inline with the tach signal. Just havent been able to find any info about which resistor to use.
3-o2 sensors...I am hoping to use the 4banger o2 sensors, does anyone know if they differ between the 2 engines?
I know this is my first post, but thats because I try and read as much as possible before looking like a complete moron(I don't need any extra help there)
Old 09-20-2010, 10:09 PM
totally a bro
Staff
vital22re's Avatar
how about some more info. what is the donor truck what is the recipient? years?
Old 09-21-2010, 05:38 AM
85flopped's Avatar
I guess that might help a little bit
97 tacoma factory 3rz replaced with 3.4 from 96 4x4 manual trans from 4runner
Old 09-21-2010, 05:44 AM
dntsdad's Avatar
1. I would surely swap the sender.
2. Most of the tach mods here are going to be for the 3.0 tach. I think that you may be best in swapping the gauge for a 3.4 gauge, or finding a 3.0 tach and adding the resistor as documented in many threads including mine. Maybe someone else can give more specific info, but I am thinking that trying to run a 4cyl tach may be more trouble than its worth.
3. No idea
Old 10-06-2010, 09:05 PM
85flopped's Avatar
Well. The temp sensor issue ended up being a ground that I never grounded. I bought a v6 tacoma cluster and the tach works like a charm.
My new problem is........check eng light is on and all the scan tools I have used wont communicate with the ecm. according to everything I have checked all the pins are in the correct location, I am unaware if the obd port worked prior to the swap or not. The one thing I do find strange is the power wire in my obd port reads 12v. but when I do a resistance to ground check it reads 0ohms. That has got me thrown for a loop bigtime. It got dark out too fast to really screw with it much more and I ran out beer. Any help on the obd port would be great. I have read the few threads about obd ports on here and have checked pretty much everything everyone else had issues with.
Old 10-07-2010, 05:29 AM
dntsdad's Avatar
You are probably getting 0 ohms with the key off. What about with the key on?
Check your wiring again. You probably have overlooked something. I know thats not all that helpful, but still probably the best medicine.
Old 10-07-2010, 07:43 AM
85flopped's Avatar
I have question I haven't been able to figure out. The wire that comes from the ecu to the obd port shows that its a shielded wire. How important is that? Meaning I think that wire might be the source of my issues and I want to run a new wire straight from the ecu to the obd port. Does it have to be a shielded wire?
Old 10-09-2010, 07:03 AM
85flopped's Avatar
Got it. The wire that goes into the OBD2 port was in the wrong pin location, so either the ewd was wrong or I am completely retarded. I had it in that location from the factory but the wiring diagram showed me that it needed to be in pin 7 not 2. in pin 2 it works. Now I can reassemble dash and get some!
Old 10-09-2010, 11:09 PM
85flopped's Avatar
Went out and got a some miles on it today. I am really impressed with the power and I have owned 2 others with this motor just forgot how much power they really have. The only code it throws is a speed sensor fault, I dont have to worry about emissions so I dont really care. Just going to buy a cheapo scan tool to keep in the glove box.
By the way I am using my 4 banger o2s no faults yet I will update if anything shows.
Old 10-09-2010, 11:24 PM
RMA
RMA's Avatar
yea according to this the o2 sensors are the same between the two trucks
upstream and downstream
http://shop.oreillyauto.com/ProductG...=1995&End=2000
part#13104
1995 Toyota Tacoma
.L4 2.4 Liter FI - VIN U
.Regular Cab L4 2.7 Liter FI - VIN U
.L4 2.7 Liter FI - VIN U
.Regular Cab V6 3.4 Liter FI - VIN V
.V6 3.4 Liter FI - VIN V
.SR5 V6 3.4 Liter FI - VIN V
.Regular Cab L4 2.4 Liter FI - VIN U
1996 Toyota Tacoma
.L4 2.4 Liter FI - VIN L
.Regular Cab L4 2.7 Liter FI - VIN M
.L4 2.7 Liter FI - VIN M
.Regular Cab V6 3.4 Liter FI - VIN N
.V6 3.4 Liter FI - VIN N
.SR5 V6 3.4 Liter FI - VIN N
.Regular Cab L4 2.4 Liter FI - VIN L
1997 Toyota Tacoma
1998 Toyota Tacoma
.DLX V6 3.4 Liter FI - VIN N
1999 Toyota Tacoma
.L4 2.4 Liter FI - 2RZFE DOHC
.DLX L4 2.4 Liter FI - 2RZFE DOHC
.L4 2.7 Liter FI - 3RZFE DOHC
.DLX L4 2.7 Liter FI - 3RZFE DOHC
.V6 3.4 Liter FI - 5VZFE DOHC
.DLX V6 3.4 Liter FI - 5VZFE DOHC
..DLX V6 3.4 Liter FI - 5VZFE DOHC
2000 Toyota Tacoma
Old 10-12-2010, 04:42 PM
85flopped's Avatar
Well I am trying to think of a way to trick my computer that the car is always still--speed signal 0mph. i have a cable driven speedo so I need a cable coming from my speed sensor to move the needle, I am guessing that since the motor came from a 4runner that it had abs and there fore wheel speed sensors. I cant use the marlin adapter or else i wont have an actual speed guage. any thoughts on how to simulate a not moving speed signal to the ecu?
Old 10-12-2010, 05:15 PM
85flopped's Avatar
Nevermind. After a little more reading it looks like the cluster will convert the speed signal for the ecu, I swapped the pin to where it says it should have been and went out and drove it, my obd2 scan tool was reading a speed signal so I am hoping like hell thats all it was, I will report more if needed.
Side note...I am going to need a new rear leaf pack this thing is getting some serious axle wrap with the new found power
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
exporunner
3.4 Swaps
08-03-2015 06:10 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Gevo
07-29-2015 11:15 AM
GeoRoss
07-24-2015 03:03 PM
Quick Reply: 3rz-5vz swap
