3.4Auto 4Runner swapped into a 3.0Manual Pickup dream machine>Issues
So im kinda confused with all this wiring stuff. Im want to do a swap on mine.
my 3.0 has a manual tranny, if i get a T100 with a manual will I have any ECU problems?
you'll be alright, but youre still gonna have to rewire lots of body harness stuff to make it work unless you go with that ungodly expensive wiring harness they talk about in alot of places on here
Please answer this
I still haven't really understood if it's safely easy to swap a 3.4 with auto into my 3.0 with manual and wanting to
keep my manual. Please let me know what steps have to be takin there.
#25
Make sure you get the pigtail for the body harness. (Last plug on the ecu) from the donor, cause i had to solder directly to the pins on the last port to make it work.
In order to make it work, you just have to close the circuit for the prndl switch. (Make it think its always in park) otherwise it wont start.
I dont remember which wires need to be jumped for this, but it shouldn't be too hard to find this info with a bit of google foo.
Good luck. I had to let my yota go last year, but it was a beast. If you need any more help, let me know. I know the frustration of forum crawling dead forums to no avail.
#26
96 4 Runner ecu and plugs
If u are still looking for an ECU I have a M/T 4X4 Ecu and all the plugs for the repin , sell I found a harness and ecu out of a 02 Taco no longer need this one
punk1sk8er
7
06-24-2015 01:33 PM
