3.4 wiring help needed
Old 08-23-2012, 06:02 AM
  #121
NytWolf's Avatar
My first thought is a bad throttle position sensor (TPS). Check your service manual for procedures how to test it.
Old 08-23-2012, 08:17 PM
  #122
toyotanick's Avatar
hmm, ok ill look into that. anyone else have any ideas?
Old 08-24-2012, 09:33 AM
  #123
anthony1's Avatar
check engine light comes on? codes?
Old 08-25-2012, 08:04 PM
  #124
toyotanick's Avatar
no check engine or codes. its very odd. it also isn't as obvious if i creep through it compared to if i get on the gas.
Old 08-25-2012, 08:05 PM
  #125
NytWolf's Avatar
Instead of just posting to this thread, have you done any diagnosis?
Old 08-26-2012, 07:52 AM
  #126
dntsdad's Avatar
I agree on the TPS. That would be my first test/swap to check.
Old 08-26-2012, 02:31 PM
  #127
anthony1's Avatar
could it be a bad MAF?
Old 08-27-2012, 08:10 AM
  #128
NytWolf's Avatar
No...
Old 01-03-2013, 06:45 PM
  #129
toyotanick's Avatar
recently brought truck to be tuned and even with a 14gph meth nozzle i am still a little lean up top so i am in search of supra injectors.
the question i have is fuel pump based. when i upgrade injectors to whatever they may be( i think i read 305cc supra injectors? i dont know what year etc yet though) will i need more fuel pump to push them? the swap truck is a 1994 toyota pickup with a 3.0.
Old 01-04-2013, 06:13 PM
  #130
slacker's Avatar
the 7Mgte stock injectors are 440 .. I went with some RC 550 cc's for my 2WD swap , so I have some supra injectors for sale ..
Old 02-12-2013, 06:55 PM
  #131
toyotanick's Avatar
hey guys, i have been having this problem for quite a while. my ac works great but my truck doesnt seem to know that the compressor is engaged so my idle drops ridiculously low. hamish_18 led me to notice that i have 2pins missing that are suppose to be there to tell the ecu that the a/c clutch is engaged. Not only have i forgotten what pins but i do not what i am suppose to bring to those pins?
Old 02-12-2013, 08:37 PM
  #132
vasinvictor's Avatar
Check the sticky thread, there's one I did for the A/C. There is no provision for A/C idle up in those wires you speak of. My idle dips for a split second, but always returns to 550-600. I've considered wiring in an idle up valve tied to the compressor clutch wire similar to the 3vze.
Old 02-16-2013, 04:42 PM
  #133
toyotanick's Avatar
my cousins tacoma does idle down at all i dont believe...
Old 02-17-2013, 07:47 AM
  #134
Mine doesn't either. It is always 500-600 rpm no matter compressor on or off. Check how I laid out the wiring, and see if you have it wired that way. You shouldn't have any problems.
5280jo
10
07-13-2015 10:05 PM
BigArt70
06-30-2015 09:51 PM
LSUMatt1514
60
10-10-2003 12:30 PM
HALMAN
06-14-2002 09:02 PM
Quick Reply: 3.4 wiring help needed
