3.4 swap 2000 tundra ecu auto
Old 08-11-2012, 02:16 AM
JTonJuice's Avatar
im about to do my second swap.
is anyone out there running this setup
3.4 swap 2000 tundra ecu auto 2wd, we dont have smog test here. i going to be using a 5 speed manual behind it.. thanks
Old 08-11-2012, 02:53 PM
vasinvictor's Avatar
I know of one person. What seems to be the issue?
Old 08-11-2012, 04:54 PM
JTonJuice's Avatar
i was just wondering if it was possible because my first swap i use all manual ecu and repinned auto harness.. thanks i just dropped the motor in today going to do the wirings now will let u know how it goes..
Old 08-11-2012, 05:12 PM
Oh oh oh you are wanting to use the auto ECU on a manual. I read that wrong. I don't think that's gonna work. You're going to need a manual ECU
Old 08-11-2012, 07:23 PM
QuickSilver74's Avatar
i am running an 98 auto ECU with a manual trans. just find the NSS (neutral safety switch) wires and solder them together. other than that everything should be just the same as wiring up with a manual ECU. (assuming you are using the auto harness, no need to repin)
i never understood why everyone always said you needed the manual ECU.....
Old 08-11-2012, 07:35 PM
Good to know! I'll politely remove myself from this conversation now.
Old 08-15-2012, 11:17 PM
JTonJuice's Avatar
will this ecu go on limp mode if it doesnt detect the auto tran?..
Old 08-21-2012, 12:11 AM
JTonJuice's Avatar
anyone?..
Old 08-21-2012, 10:51 AM
Pehaps you didn't read post #5?
Old 08-21-2012, 10:35 PM
JTonJuice's Avatar
i have read number #5 but i heard the newer ECU revs out lower when its in park or nuetral.. Found out for my self today got it fired up and rev it pass 5,000 so it should be fine..thanks
Old 08-30-2012, 05:44 AM
mine has no issue on anything other than throwing codes for the auto trans that isnt there. everything else works and drives perfectly
Old 08-30-2012, 11:06 PM
JTonJuice's Avatar
thanks she run like a champ...
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
mskalmus
05-28-2017 07:51 AM
mengquis
07-13-2015 10:39 AM
94whiterunner
07-12-2015 07:15 PM
Quick Reply: 3.4 swap 2000 tundra ecu auto
