3.0 to 3.4 swap WIRING!!
Old 12-15-2008, 10:27 AM
  #61
syber_kowboy's Avatar
I've got 2 1/4" as well and a high flow cat and a pretty decent muffler. It's not silent and sounds pretty good up to about 4000 RPM then the vibrations start rattling.
Old 12-15-2008, 11:16 AM
  #62
cartune777's Avatar
maybe ill have to run 2 1/4, the muffler is right under the drive seat and the interior noise is nuts
Old 12-15-2008, 01:32 PM
  #63
cadman's Avatar
Yeah, the exhaust noise is going be pretty loud in the cab if your system exits under the vehicle.
Old 12-21-2008, 07:11 PM
  #64
Does anybody know about a wiring switch that took place between 90 and 91? It's frustrating the crap out of me.
Old 02-09-2009, 05:08 PM
  #65
Tragic Drive's Avatar
Originally Posted by cartune777
does any one know how a cheap turbo muffler sounds on the 3.4, right know it has a flowmaster with 2.5 tubing, i really dont like the sound of it
I have the same question . I've installed 3 different mufflers over four years on my swapped 4Runner and still cant find a good tone from the exhaust. Magnaflow, Menike turbo, and now Flowmaster on my 2.5" exhaust all sound like crap.
Maybe Jardine next I dunno.
Old 01-01-2010, 08:44 PM
  #66
4runnerman88's Avatar
O.k not to sound like I am but I am color blind.... that being said all of this wiring makes a MAJOR problem for me.
Is there a wiring diagram that shows what wire in the 3.0 connector does what, so the 3.4 connector can be pulled one by one and reconnected without screwing myself up totally?
If I am looking at this correctly the major problem with this swap is the wiring? Well the mechanical problems are really not problems, just need a little common sense. I am very confident in my mechanical ability thats not a problem. I recently about 3,000 miles ago rebuilt the 3.0 in my '88 and am totally disgusted with the lack of grunt. Looking at this swap its much easier than a SBChevy and should cost ALOT less.
Also there are very few upgrades for the 3.0 (that cost an arm and a leg), and there seems to be many upgrades for the 3.4 that seem to be more cost effective for the power returned .
I have had very few complaints with the reliability of my 3.0, the reason for the rebuild was self inflicted, the piston rods seem to bend when water is sucked into the compression chamber
Is there a dummyproof fix for this sort of issue?
Old 05-19-2011, 07:09 PM
  #67
flaunt's Avatar
blast from the pastt!
so the overall outcome of this was to take the smaller gauge b/w wire from the starter and splice it into the bigger gauge b/w wire that is located in the fuse box under the hood that goes to the starter relay?
thanks
Old 05-21-2011, 01:04 PM
  #68
flaunt's Avatar
anyyybody?
its the bigger gaugge b/w wire that goes from the starter relay to the am1 or am2?..am i supposed to splice the smaller starter b/w wire into that?
Old 05-21-2011, 02:22 PM
  #69
dntsdad's Avatar
Originally Posted by flaunt
anyyybody?
Man this thread is all over the place
Flaunt.....what exactly is your issue?
For the starter circuit, you will have a large black/white wire in the kick panel. That is FROM the ignition switch and is hot when the key is cranked. You will need to run your own wire from the SMALL terminal on the starter, into the kickpanel, and join it with that larger wire. Also, in that splice you need to extend a small wire that will join to the STA terminal off the ECM.
If you search around I made a terrible picture kinda showing everything. I can t remember which thread though.
Old 05-21-2011, 02:36 PM
  #70
flaunt's Avatar
in the passenger kick panel where the ECM goes?..
i thought it was in the hood fuse box where it was labeled starter for the relay, because there it has that same bigger b/w wire.
so look for the starter circuit in the passenger kick panel?
thanks!
Old 05-21-2011, 06:10 PM
  #71
dntsdad's Avatar
thanks!
Thats where I got mine.
I never messed with a single wire under the hood that I can recall. Everything that I needed was in the passenger kick panel. Yes, where the ECM goes.
Old 05-21-2011, 10:59 PM
  #72
flaunt's Avatar
is this where im lookin?...only thing in the kick area
Old 05-23-2011, 03:10 PM
  #73
hamish_18's Avatar
That is your Circuit Opening Relay. down lower you should have two more plugs, those are your body harness plugs, that splice with the engine harness, and ecm.
Old 05-23-2011, 04:36 PM
  #74
dntsdad's Avatar
Exactly. that blue wire in the plug you have highlighted is the wire that run to your fuel pump by the way. You will run a relay from the FP terminal on the ECM to that blue wire. I believe it has a white stripe but I could be wrong......AGAIN USE A RELAY!!
As to the starter wire Hamish exactly right as usual. Lower. Larger wire than the rest......like 12 ga.....maybe 14. Will be hot when key is turned to start.
Old 05-23-2011, 06:07 PM
  #75
flaunt's Avatar
alright im going to the shop to check it out today. you guys are good help as always! ill let you know the status...i know this isnt the right thread but since this thread is all over the place anywaysi figured why not. i already made another thread and no response so i didnt wanna make another one.
anyone know what this plug is for on the a340f tranny?
Old 05-25-2011, 08:43 AM
  #76
hamish_18's Avatar
I am betting it is this:
T 2 2−4 Select Motor
That is the farthest back plug on the tranny that is on the driverside. Did that tranny come with the manual 4wd shifter? or the 4wd switch...
*edit. Or one of these:
D 3 Detection SW (Transfer L4 Position)
D 4 Detection SW (Transfer Neutral Position)
But I am pretty sure both 4wd plugs are greenish/blue. So the only other possibility is the neutral position switch???
Old 05-25-2011, 08:52 AM
  #77
hamish_18's Avatar
okay this is it:
Its the other vehicle speed sensor for the Auto ECU part
Uploaded with ImageShack.us
Do I get a cookie now??
Old 05-28-2011, 10:38 AM
  #78
flaunt's Avatar
yeah a big ass one haha..
thats 3.4 or 3.0 wiring sch.?
Old 05-28-2011, 07:50 PM
  #79
hamish_18's Avatar
I got that from a 99 4runner schematic. So the wire colors may be off. I found it in the drivetrain section, file 036EA-5VZFE.pdf.
So hopefully you have all of the EWD's for your donor year, and you can find that pdf. the screen shot was from the first page of the pdf.
cheers!
Old 06-01-2012, 06:44 PM
  #80
vasinvictor's Avatar
Start you own thread, with specific questions, rather than bumping a year old thread with absolutely no detail- please.
MO transplant
04-23-2023 11:58 AM
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
steve miller
10-10-2015 01:40 AM
toyota32
07-06-2015 05:42 PM
Quick Reply: 3.0 to 3.4 swap WIRING!!
