22r to 5vz swap
#81
Some of the early 5vz's did have a recall on the headgaskets. X01 was what toyota called it, but I looked around breifly and couldnt find anything on it anymore. I wouldnt worry about that when buying your engine (I didnt) but if you are worried I think it was only the 1996 engines that had that recall on it, all of the others got the new headgaskets.
As far as the wreck, I was going maybe 10mph at the most. I dont know haw fast he was going but maybe 35-40??
#84
Thanks, I appreciate it
I agree, the lift did help as well as the bumper. Had either one not been there the truck would have been totaled.
#85
Sweet build; I'm tempted to do the same here in CO with my 84. I heard from a Toyota dealer mechanic that some of the 3.4s had similar head gasket issues as the 3.0 engines; did you run into anything like that during your build?
Also glad your truck isn't mashed like that Ford... how fast were they going?
>>Dan
>>Dan
#86
hey jason, was there a specific reason you went with the 95-00 model engine? i am looking at an 01-04 3.4 for an 80 pickup. the price is right. just wondering if i should go with an older engine though. . . thanks
mark
mark
#91
I'm starting a swap in my 93 4X4 pickup. I have a complete 96 T100 4X4 for parts and such. I'm gonna install the 3.4 and 4X4 5 speed transmission. The crossover pipe tutorial is amazingly helpful. The biggest issue I expect to have is mating the wiring harness to my truck.. I have the complete engine harness and ECM. There are about 18 wires on two plugs that have to be crossed.
My opening question is: Are the wiring color codes the same from the 93 22RE to the 3.4 from the T100?
Any wiring suggestions will be helpful.
thanks in advance,
Scott
thanks in advance,
Scott
#92
thanks in advance,
Scott
thanks in advance,
Scott
nframe
3.4 Swaps
08-16-2015 09:03 AM
Avenged
07-09-2015 07:55 AM
