2000 Taco 5sp 3.4l into a SAS'ed 1995 PU 5sp 3.0l
Old 12-24-2009, 05:40 PM
  #161
totally a bro
Staff
vital22re's Avatar
would you be so kind as to maybe give out the part number for the hood scoop? also are you running a body lift of anykind??
Old 12-24-2009, 10:36 PM
  #162
neoworm0's Avatar
No body lift. I don't know what luck you'll have even with a P/N. I bought the scoop from a Toyota dealer in Greece.
I'll see if I can dig the receipt up somewhere though and I'll post the PN up for you.
Old 12-27-2009, 08:24 AM
  #163
osucycler's Avatar
Would like to know the p/n as well. Looks good.
Old 12-27-2009, 04:39 PM
  #164
neoworm0's Avatar
Sorry guys, I can't seem to find the receipt anywhere. If I ever come across it I'll post it up.
Old 01-10-2010, 09:56 PM
  #165
4x4runr's Avatar
Anybody know if the block and engine wiring harness from a 1997 3.4l T100 4x2 work on a 1997 3.4l 4x4 ecu? I had the ecu from the original donor but the truck got hit in that area and the ecu is shot....
does it matter if its 4x2 or 4x4?
right now all i need for my conversion would be the ecu.... and of course the exhaust part. but im not worried about that part. its the dang ecu
This is a manual trans btw.
HELP ME PLEASE lol
Old 01-12-2010, 06:38 PM
  #166
Ahbustae86's Avatar
Originally Posted by neoworm0
I don't have AC so I was able to route the starter trigger wire up through the grommet that fills the top AC line hole. 12 inches below that there is another grommet that I ran the tcase position switch wiring through.
[IMG][/IMG]
This might be a dumb question , but what is the T-case switch for and where is this wire coming from. Thanks.
Old 01-12-2010, 08:34 PM
  #167
neoworm0's Avatar
There is a switch on the side of your transfer case. It's up near the top close to your shifters on the passenger side. It pretty much just functions to operate the light on your dash that tells you you are in 4wd.
Take a look. If you can't find it I think I have a pic somewhere I can post up.
Old 01-12-2010, 08:58 PM
  #168
Ahbustae86's Avatar
Thanks man. So I just need to splice into my 91 4runner wiring to wire up the switch on my gear driven T-case?
Old 01-13-2010, 07:01 AM
  #169
neoworm0's Avatar
It's been awhile but I think you woulld have to route it to the IH2 or IK2 conector (can't remember what they are called) or maybe even the 3.4 ECU.
Probably not the ECU since on the older trucks having it in 4wd doesn't disable any other features that I can remember. It probably JUST operates the light.
You need to look at some wiring diagrams.
Old 03-02-2010, 06:34 PM
  #170
darkangel197431's Avatar
I like it. gonna start my own 3.4 conversion soon.
Old 03-02-2010, 10:10 PM
  #171
neoworm0's Avatar
Thanks! Make sure you post up some pics.
Old 03-03-2010, 04:36 PM
  #172
Gonna try. going throught the process of getting everything together. And gotta rebiuld the 3.4 first. It spun a rod. The truck it's going into is an 89 X-tra cab with the 3.0 and an automatic.
I found a 5 speed for it for $300. got the motor with the wire harness, coils, intake, for $350 and a two hrs drive. Slowly but surely.
That and on top of it all. I have a 4 1/2 yrs. old at home. Her momma's in Iraq. So I have a full plate
It's All Good.
Old 10-10-2010, 09:04 PM
  #173
neoworm0's Avatar
Update:
Well it's been on the road for just shy of 18 months since the swap was completed and not a single issue. It's been wheeled hard for 2 seasons and runs like a top. Still lovin this swap. Definitely pays to sweat the details.
Old 11-17-2012, 07:00 PM
  #174
Austin Marr's Avatar
Awesome thread man! you do clean work! I did all the wiring myself and the only drag up i've got is the RPM gauge and the Speedometer. I have an electronic speed sensor and had to run 3 wires to my ECU but im not sure where they go to. im curious if any of them go to the ECU? any suggestions? my wire colors are different then yours but any help would be great
Old 11-17-2012, 10:38 PM
  #175
westjohns yota's Avatar
ive been looking for a 3.0 likes uour for awhile but everything down here is over priced, def a clean swap, just read your whole build and im impressed!
Old 01-05-2013, 05:21 PM
  #176
neoworm0's Avatar
Thanks guys. Unfortunately the site that was hosting my pics is no longer. Looks like this thread is toast!
Old 03-05-2016, 08:10 AM
  #177
wolfrunner's Avatar
Any chance you have the pictures saved somewhere that you can retrieve them? That's the worst part of trying to use this site for a swap. All the popular swaps like yours wont show any pictures.
Swim
9
01-04-2016 10:47 AM
falcon4runner
3.4 Swaps
08-06-2015 02:36 PM
jbandt
08-03-2015 03:23 PM
defrag4
07-31-2015 10:50 AM
1996Taco
07-20-2015 12:02 AM
Quick Reply: 2000 Taco 5sp 3.4l into a SAS'ed 1995 PU 5sp 3.0l
