1990 2 Door 3.4 Swap
Old 02-05-2012, 05:59 PM
  #41
Countryhick's Avatar
lol i pull alot of things when i go out of town so my truck gets stolen and ive forgotten to turn on a kill switch once and went around my truck for hours and then Yeah.
My friends still dont know what it was... lol
Old 02-07-2012, 12:34 AM
  #42
4x4runr's Avatar
Bought me a voltmeter....there is power to ignitor and ECU, but it seems the ecu is not working....no check engine light when ignition is on "on".....
Anyone know if I can use another ecu? Could I use a tacoma or 4runner from 1996-1997 that is a manual trans?
Donor is a 1997 T100, 2WD, Manual trans.
Thanks in advance
Old 02-08-2012, 06:05 AM
  #43
93NMyota's Avatar
I had the same problem, no start and no CEL when you turn the key on, turned out to be the MAF, it was shorted internally and sent back feed to the ecu. I didn't think it would be the MAF because it wasn't those symptoms but it was. I chased this for a few days! I bought another ecu and it did the same. I would unplug one sensor at a time and check it again at the CEL to see it turns on, it could be something else but i would check this first
Old 02-08-2012, 04:29 PM
  #44
4x4runr's Avatar
I hooked up my OBDII scanner but it doesn't read. I'm thinking the ecu is not working.
Old 02-09-2012, 05:50 AM
  #45
93NMyota's Avatar
do you have switched 12v power at the purple wire at the OBDII port?
Old 02-09-2012, 07:03 AM
  #46
4x4runr's Avatar
I have power. Scanner just scans "looking" for the ecu. I h ave power to ecu, and igniter, and grounds to both. I just need to find someone willing to hook up my ecu to their T100.
Old 02-09-2012, 07:28 AM
  #47
vasinvictor's Avatar
Where are you checking for power to your ECU? On mine I have IH1-10 to E12-14, and IH1-16 to II3-16. Former is to ECU "Batt". Latter is ECM +B. I'd be getting on the phone with ORS, if you haven't already. They should support this.
Old 02-09-2012, 01:45 PM
  #48
4x4runr's Avatar
Yes, Mike and I are communicating very well and he is being really helpful which is how I was able to check for power.
Old 12-08-2012, 12:46 AM
  #49
4x4runr's Avatar
Been really busy with work lately and haven't had the chance of working on it till this week..actually only took 2 days.....
IT'S ALIVE!!!!!!!!!!!!!!!!!!!!!!
Problem was the VP sensor, it was shorting out the ecu, all I did was unplug it, scanner read the ecu and bam! turned key
Old 12-17-2012, 03:26 AM
  #50
4x4runr's Avatar
Taking it to the muffler shop tomorrow
Been driving it around my yard, thermostat was stuck so I removed it (for now). Radiator seems to be working fine, no leaks, steering column is hitting the alternator, but i will be changing my steering setup in a few weeks so no biggie. Can't really run the motor hard to really feel the gain till I break in the motor and clutch. So far all is good Can't wait to hear what the exhaust will sound like, I did a lot of youtube research for the right sound hahahaha I hope it pays off......
Old 12-18-2012, 12:42 AM
  #51
4x4runr's Avatar
Drove it home from the muffler shop today and it sounds perfect for what I wanted! Thank you youtube lol. Throttle response is amazing and has lots of power. Really enjoying the sound of the intake too. Idle is really high so hope to get that fixed soon. I read twice here where the IAC Valve was replaced so I might just end up doing that. Throttle cable is not pulling so I think the IAC is the culprit. All in all, really enjoying the swap even though I only drove it less than 4 miles
Old 12-18-2012, 12:45 AM
  #52
4x4runr's Avatar
I forgot to mention, tach mod works, and oil sending unit working also. So far it's just the VP sensor that's not working for me. A small problem since I am on Guam
Old 12-18-2012, 03:59 PM
  #53
blacksc's Avatar
what is a vp sensor?
my truck is doing the same thing i have wired up my truck and there is no check engine light or nothing
Old 08-14-2013, 06:16 PM
  #54
4x4runr's Avatar
Originally Posted by donomite49
looks good!! lookin for a radiator for my swap. how does yours look quality wise?
I know it's been over a year but to answer your question. Quality is great, no leaks, holds lots of pressure and all metal like the original
Old 08-14-2013, 06:19 PM
  #55
4x4runr's Avatar
Is there a 'post your pics for 3.4 swaps only' thread here? I think it would be nice for us to share all our work in 1 single thread where we can post the specs and even vids?
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MMA_Alex
25
04-18-2017 05:07 AM
colasurdo
07-16-2015 11:32 AM
94whiterunner
07-12-2015 07:15 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: 1990 2 Door 3.4 Swap
