WTF is this haze on my windows?
Old 09-23-2002, 08:38 AM
Mohamed's Avatar
Angry WTF is this haze on my windows?
See this is why I need to pay someone to wash my truck! Sheesh! Everytime I wash my car and then try to clean the interior and I think I got everything, the next day I am still left with this haze on my windshield that makes the road glarry. And the thing is, this haze is only wiped off with my hand, my damn red terry cloth won't work on clearing the haze off. Is this windex residue? Sorry I didn't take a picture.
Mohamed is offline
Old 09-23-2002, 09:01 AM
AZTOY's Avatar
the haze
This may sound funny but the best thing i found for clean windows is news papers Works Great
AZTOY is offline
Old 09-23-2002, 09:24 AM
Cebby's Avatar
Windows
I've been using a product called ClearVue autoglass cleaner that works great. However, I don't think the cleaning product you are using is the problem. I'm with AZTOY, newspaper works great. The only downside is you get news print all over you hands. I did that method for a good while when I competed on the sound scene. I've since been using those glorified blue paper towels they call shop towels. The trick is to not try to stretch how many windows you can get from each sheet. For example, I use 1 on each inside door window, two on the inside of each of the cargo windows, and 3 on the inside of the windshield. I use an equal amount on the exterior. I use enough cleaner to wet the window, but I don't saturate it to the point where its flowing down into the weather stripping. Anyway, that's what works for me.
Something else that could be causing the streaking is if the towel you are using is picking up any protectant (Armor All, etc) from adjacent surfaces. Personally, I've never been happy with the cleaning results of using a cloth towel. Just my 2 cents.
Cebby is offline
Old 09-23-2002, 10:28 AM
Co-Founder/Administrator
Staff
kctopher's Avatar
Back when I worked for Toyota every tercel had a real bad problem with this. I was told it's because the dash (and plastic parts), that when in direct sun (and windows up) it will emit this gas that creates a film that is only noticeable on the interior windows..
Sounds crazy I know, but your car might do that for a while because its new....
kctopher is offline
Old 09-23-2002, 10:43 AM
Senior Member
data's Avatar
i have that exact same problem! i will wipe that stuff off and then the next morning/nite, I will notice that it is there again!
:wtf:
data is offline
Old 09-23-2002, 11:52 AM
hawkdog21's Avatar
ME TOO, the haze really pisses me off. It also happens when i use Rain-X
hawkdog21 is offline
Old 09-23-2002, 03:50 PM
rowan's Avatar
have you ever tried the armorall window wipes? i use their protectant wipes all the time, and they are AWESOME.... but on my windows.. well i havnt cleaned those at all yet, but id probably just use a rag and some water maybe. but might try out some of those armorall window wipes.
if you have used those let me know what you think. thanks.
rowan is offline
Old 09-24-2002, 08:21 AM
mark from uk's Avatar
If you live or drive in a city then it is probably smog
mark from uk is offline
Old 09-24-2002, 10:04 AM
Mohamed's Avatar
lol...probably not, SMOG is HC+CO2, NOx, and particulate matter, unless my windows is sporting a 405 block, I seriously doubt it!
Mohamed is offline
Old 09-24-2002, 12:39 PM
Bob_98SR5's Avatar
Mohamed:
KCtopher is right---its the plastic they use which gives off a chemical that adheres to the window quite well, as you have experienced.
On the Toyota owner's club website (yes, on their corporate website), they have a little FAQ on this. I remember reading it a few years ago.
My wife has a 95 Camry that does the same thing. I can't stand it and like Cebby, I purchsed those Armor All Window Wipes. Those things kick butt, but I wonder how long the moisture will last in this blarsted CA heat!
Bob
Bob_98SR5 is offline
Old 09-25-2002, 07:24 AM
cpw2002's Avatar
I used a damp paper towel and applied white vinegar to the towel, cleaned window and wiped with a dry paper towel. The windows came clean for me.
It felt almost like a grease. I thought it was a protective coating used by the glass manufacturer to maybe keep from scratching. Your explanation sounds better.
There are windex wipes now, the main ingredient is ammonia but should also work well. The vinegar doesn't streak or get cloudy.
cpw2002 is offline
Old 10-07-2002, 05:40 PM
Dandeman's Avatar
Haze from the Plastics
It's called outgassing.. Its the more aromatic solvents used in plastic that gasses out when heated..
Don't know about the product advertised here, but the link explains the problem fairly well http://www.nuviewplus.com/about.html
Learned about this stuff in the computer industry as the plastics inside your computer does the same thing, only there, the concern is this mess getting in connectors and causing intermittent problems.. good quality connectors are designed to cut thru deposited films as they are plugged together. This link illustrates another example of the concern http://www.boedeker.com/outgas.htm
When all this stuff has gassed out of the plastic, that is when it becomes brittle and cracks.. think of it as your plastic dash slowly evaporating away... :rolleyes: :rolleyes:
Did some google searching and this article http://www.geocities.com/MotorCity/T...5/bodies03.htm (of all things on the plastics used in slot cars) was most informative. ABS is commonly used plastic in the interior of vehicle.. It's now easy to tell as for recycling reasons, if you look on the back side of almost any plastic part, you'll see "ABS" stamped on it..
Dandeman is offline
Old 10-25-2002, 04:40 AM
SLC Punk's Avatar
Originally posted by Bob_98SR5
Mohamed:
Bob
I also heard the same thing that Bob and CKtopher said before. Anyways I clean my winshield 2 times a week.
I think that all toyota's do it because my mom's 2003 Lexus ES300, my 93 camry, my sisters 2001 camry, and my bro's 02 IS300 all do the same thing!! Its a Toyota curse.
SLC Punk is offline
Old 10-25-2002, 04:43 PM
Jeff's Avatar
I don't think it's a Toyota thing. Every aout I have had since around 1990 has done it.
89 Mazda 323
95 Toyota Corolla
97 Mustang Convertible
2000 Chevy Silverado
2002 4Runner (Wifes)
Jeff
Jeff is offline
Old 10-28-2002, 05:25 PM
L33T35T 4Runner's Avatar
Re: the haze
yup, works great.
L33T35T 4Runner is offline
Old 11-11-2002, 06:43 PM
what about putting a dashmat on it , will that help with the outgassing of the dash or atleast filter it some
Richard is offline
Old 11-11-2002, 08:17 PM
Mack's Avatar
If you don't want newsprint on your hands you can use buthers paper
Mack is offline
Old 11-21-2002, 12:13 PM
Outkast`'s Avatar
__________________________________________________ __
Yup...this will keep you haze free
Outkast`
Outkast` is offline
Old 11-21-2002, 07:17 PM
03DCTACO's Avatar
You guys otta try love bug season in Florida or fall when the trees start sappin. YUCK!!! Clean the damn windows daily
03DCTACO is offline
Old 11-22-2002, 05:28 AM
Mohamed's Avatar
Outkast`
Do you guys straight shot use the newspaper or do you spray with windex also? It came back again this week so i am going to clean once again this weekend.
Mohamed is offline
RDubya
02-10-2017 04:46 PM
PNW94Runner
09-29-2015 02:55 PM
tazman1972
11
09-28-2015 10:32 PM
punks_is_4x4
09-19-2015 05:52 AM
mat
09-17-2015 11:18 PM
Quick Reply: WTF is this haze on my windows?
