valve adjustment 3.4v6?
Old 09-28-2003, 02:23 PM
justinh's Avatar
anyone had to deal with this, my 1997 4runner with 128k on the clock is making some valve noise. carmax tells me it isn't a warranty issue but is a maintenance issue and they need to be adjusted. so far i have spoken to two toyota dealerships and both have said that they do not adjust the valves. when i questioned that one dealership said that it is possible for them to go in and shim them but it isn't a recommended/required maintenance issue. anyone else have any experience?
justinh is offline
Old 10-03-2003, 12:01 AM
morg888's Avatar
I think I have the same problem what kind of noise are you hearing?
morg888 is offline
Old 10-03-2003, 06:05 AM
justinh's Avatar
it is just light valve tap, mine is coming more from the left side
justinh is offline
Old 10-03-2003, 06:12 AM
rimpainter.com's Avatar
Its a very involved process. You have to add or remove shims to make the adjustment. Best left to the pro's, even if it costs a pretty penny.
Gadget knows a thing or two about this. In fact, there have been a couple threads going in the past. Check it out.
rimpainter.com is offline
Blamalam
03-12-2022 07:34 AM
Jason Webber
09-02-2015 03:30 AM
DukeOfHazard
08-16-2015 01:48 PM
Dennisx2
08-04-2015 01:26 PM
razorman8669
07-12-2015 12:13 PM
Quick Reply: valve adjustment 3.4v6?
