power steering leak
Old 04-27-2003, 10:27 AM
fooddude's Avatar
power steering leak
i have a power steering leak in my second gen runner what is the easiest way to find where the leak is.
fooddude is offline
Old 04-27-2003, 10:40 AM
Victor's Avatar
I have a leak too. There is an electrical connector in the side that has an 0-ring for a seal and that is where mine leaks. It is a very slow leak so I haven't messed with it.
Victor is offline
Robinhood150's Avatar
Power steering pump leak is a fairly common thing on old 2nd gens. 3.0, right? Toyota has a seal rebuilding kit for about $35. I just had a garage rebuild mine and with labor it was $330.
Robinhood150 is offline
Old 07-17-2003, 05:18 PM
mynameisjonas's Avatar
What all does that kit entail? i'm guessing since you took it somewhere it is pretty difficult to rebuild? And was that $330 removing and reinstalling the pump too?
mynameisjonas is offline
Old 07-18-2003, 04:19 AM
anondrao's Avatar
mine leaks somethin fierce...
how difficult is that to do?
anondrao is offline
Old 07-18-2003, 09:44 AM
JSB
JSB's Avatar
Well I'll chime in I guess, because mine has a slow leak as well. One of the board members found that his hose had gone bad where it connects to the pump. He replaced the hose and it was fixed. The dealer told me I needed a new pump and I can't remember the amount but it was way too much. I don't have to refill it that often.
JSB is offline
Old 07-18-2003, 11:57 AM
92runner's Avatar
It might just be the seals have dried out from age. Mine was leaking slowly (add about once every 1 1/2 weeks) and I decided to try some PS pump leak stopper from O'Reilly figuring it couldn't hurt. Adding that stuff two times has stopped my leak completely.
Just a thought.
92runner is offline
Old 07-18-2003, 12:19 PM
I don't know what is in the kit. The only reason I had a shop do the fix is because I live in an apartment so I can't work on it, otherwise I would have done it. My guess is that it's fairly easy. Yes, the $330 included removing and installing the pump. Labor is $110/hour.
Old 09-17-2003, 03:06 PM
joshik's Avatar
i too have a leak. i havent researched it enuf to see from where... but yeh.. it leaks slow! its been doing it for a while... but since i put in the anti leak stuff it fixed it.
i have a 3.0 in it and makes some noise when i turn. thats normal yeh? just A LOT of noise is not good...??
but now recently it started again. i went on a 4 day trip to the river and left my truck in the driveway. when i got home i had a pool of powersteering fluid. so i filled it.. the dipstick read empty.. so now it leaks. imma have to research this some more. :T
joshik is offline
Old 09-18-2003, 07:18 AM
mtnfreak's Avatar
Reman pumps run about $100 at NAPA. Might be worth a look if you consider the labor cost of replacing the seals. Removal / Installation isn't that hard, just be sure to squirt some pentrating oil or PB Blaster on the nuts & bolts a couple of days beforehand (especially the pulley nut). Take out your battery to give you some extra room and to avoid a potential fireworks show.
mtnfreak is offline
Sleaker
08-26-2020 06:03 AM
tj884Rdlx
08-28-2015 12:04 PM
cars-guy
07-11-2015 07:51 PM
jon.r
07-11-2015 03:34 PM
nick b
07-11-2015 04:38 AM
Quick Reply: power steering leak
