Motive Power bleeder, how much pressure needed?
Old 03-29-2005, 11:57 PM
tx ranger's Avatar
I'm replacing my rear brake lines this weekend with the SS extended ones from Toytec, and thus will need to bleed my brakes...ordered a bleeder from Motive this afternoon, and was going through the instructions on how to use it...jsut wondering what pressure yall used on this thing to bleed your brakes? The instructions on their site say to consult my repair manual, which unfortunately I don't have. So anyone who's done it, feel free to speak up...thanks in advance!
tx ranger is offline
Old 03-30-2005, 12:31 AM
AW1090's Avatar
I think there's a write up on it that explains everything. Yup, just checked and there is sorry, but I can't copy and paste on my work computer. It's not hard to find just go to the tech section.
AW1090 is offline
Old 03-30-2005, 06:45 AM
midiwall's Avatar
And, with a quick flick of the wrist...
http://www.top4runners.com/ja/synthetic.html
midiwall is offline
Old 03-30-2005, 07:10 AM
eric-the-red's Avatar
I use about 15 psi on my Motive bleeder, that seems to work fine on my vehicles.
And as for the amount of fluid I did a 4Runner, Miata and Civic with 4 litres. Just to be sure you don't run out you probably want to get 2 litres for your truck.
eric-the-red is offline
Old 03-30-2005, 08:42 AM
jpachard's Avatar
A trick I use with the Motive is *not* putting any fluid in the bleeder itself. This requires one to be more diligent in making sure there is enough in the resivoir. The upside is that the bleeder stays clean and makes for less mess. I bleed brakes ALOT on my race car and it's really nice to not have another container that can potentially ruin paint.
As far as pressure goes, I go up to 30psi without a hitch.
Cheers, James
jpachard is offline
Old 03-30-2005, 03:09 PM
tx ranger's Avatar
D'oh, dont know how i missed those write ups...late night searches seem to be less effective Thanks for the help guys!
Old 03-30-2005, 06:15 PM
Nic
Nic's Avatar
I never got over 15lbs when I bled my car and truck. At 15lbs, I was tired of pumping and went no higher, but it seems to push out the fluid well enough even at 10lbs.
Nic is offline
BigArt70
06-30-2015 09:51 PM
LSUMatt1514
60
10-10-2003 12:30 PM
jalaber
07-24-2002 06:48 AM
HALMAN
06-14-2002 09:02 PM
Quick Reply: Motive Power bleeder, how much pressure needed?
