97 4Runner... shake at idle
Old 06-21-2005, 06:18 AM
bmwpower's Avatar
When the truck is at idle, it feels like there is an imbalance in the engine. Anyone else have this problem? I took a look at the harmonic balancer and it, too, appears to be shaking. Do these things go bad?
bmwpower is offline
Old 06-21-2005, 06:24 AM
dwh91102's Avatar
when's the last time you did a tune up on your truck, sounds like could be plugs or wires. Are you getting any kind of codes. As for the harmonic balancer they dont go bad unless there damaged. Also more info on your ride, 3.4 im sure, but mileage, is it s/c, any mods you've done. This will help out
dwh91102 is offline
Old 06-21-2005, 06:33 AM
bmwpower's Avatar
About 120K miles. The truck is completely stock SR5 V6 model. Not sure of the last time a tuneup was done, but the truck has been going through the Toyota scheduled maintenance since new. I will check my records tonight to see when a tuneup was done last.
bmwpower is offline
Old 06-21-2005, 06:40 AM
dwh91102's Avatar
something else to try is either pull it in your garage if its dark, or wait untill night time, start the truck with the hood up, get out and see if any of the wires are arching.
dwh91102 is offline
Old 06-21-2005, 06:42 AM
bmwpower's Avatar
One thing to note is that we're having an issue with starting the truck, which may be related....not sure.
https://www.yotatech.com/forums/f16/97-4runner-problems-starting-61649/
bmwpower is offline
stoneboy91
04-05-2016 05:17 PM
Charliegardmn
09-10-2015 08:42 PM
tinigunner11
08-14-2015 01:19 PM
Quick Reply: 97 4Runner... shake at idle
