Engine Swaps Swapping an engine in your Toy, here is where to learn how
what is a good radiator when doing a 350 swap
Old 10-10-2009, 10:02 PM
liftit's Avatar
im in the process of doing a 350 swap right now but i dont want to weld the engine mounts until i have a radiator that will work. ive done some research on it and found that a corvette or chevelle radiator will fit if i fab up some mounts but was just wondering if there is a better solution. also today i hoisted the 350 into the engine bay and realized its a lot snugger fit then i thought but still ok, has anyone cut the front core support and fabed it up so you can push the radiator foward a little? any info will help
Old 10-10-2009, 10:17 PM
algranger's Avatar
Probly any rad that runs with a 350
Every 350 swap i've seen has been done with a cut up core support fabbed to accommodate the rad
Old 10-10-2009, 11:07 PM
liftit's Avatar
anyone else?
Old 10-11-2009, 04:09 PM
75k5toy's Avatar
Howdy. I'm getting all parts together to do my 350 swap and I meassured a rad. from a V/8- 86 M/Benz, and I think (4 me) it will b the way to go. good luck with your swap. salud
Old 11-12-2009, 02:39 PM
96ram1500's Avatar
got mine from summit 22'' x 19'' it was around $150 for a alluminum 2 core fits looks like ihave about 2 inches of clearence between it and the water pump after some metal trimming from the rad support
Old 11-12-2009, 11:05 PM
liftit's Avatar
what was the part number on that rad
Old 11-14-2009, 09:07 AM
96ram1500's Avatar
sum-380324 its for a gm
Old 05-18-2011, 07:41 AM
Akilleez1's Avatar
radiator
im running 92 v6 4runner radiator with my 350
Old 08-04-2011, 09:21 AM
Ride4Fun's Avatar
I did a 327 SBC swap in an 85 years ago. I used a STOCK Toyota Desiel pickup truck radiator. It is thicker (larger capacity) than the gasoline engine radiator and fits directly into the stock mounts. However, as with most of these V8 swaps, you will have to run electric fans as there is absolutely no room for a belt driven fan.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
mskalmus
05-28-2017 07:51 AM
coryc85
09-09-2015 06:24 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: what is a good radiator when doing a 350 swap
