Engine Swaps Swapping an engine in your Toy, here is where to learn how
Small block swap to stock trans/drive??
Old 04-17-2013, 01:05 PM
95CustomYota's Avatar
Hello all, new to forum...have been talking to a few companies trying to figure out what is best option. LC engineering is telling me I can not run a small block 350 with stock transmission and transfer case/axles, ext... I talked with other companies and they tell me I can...so My question is...can I run a 350 small block with my stock transmission/trans case/ext? I have the 1995 pickup, 22RE , 4WD, standard cab.
Maybe there's a link to all this already that I'm not seeing?
I will be doing a complete frame off restoration this summer along with long travel suspension...getting rid of torsion bars in front, doing coil overs...maybe some info on this as well?
Thanks guys.
-Andrew
Old 04-17-2013, 05:18 PM
Vudujoose's Avatar
Check HERE--------->Domestic Swaps
There is a multitude of information on the swap you are interested in doing.
You can also check out Advance adapters.
Good luck.
Old 04-17-2013, 06:20 PM
Thank you!!
kazuya2416
04-05-2024 02:17 AM
lledwod
08-30-2016 01:03 PM
jon.r
07-11-2015 03:34 PM
nick b
07-11-2015 04:38 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Small block swap to stock trans/drive??
