Engine Swaps Swapping an engine in your Toy, here is where to learn how
88 Toyota 1UZ Swap plus MORE!!!!
Old 05-19-2009, 02:47 AM
TNRabbit's Avatar
Originally Posted by gennro
Not much for tonight just the engine is almost back together and just waiting on a few more parts to come in the mail to finish putting the engine back together. So in the next few weeks the engine will be going in the truck. So who all thinks I can't get this completed within a month? =)
I say you won't have it done in a month....
Old 05-19-2009, 05:35 AM
[N8]'s Avatar
My SC400 sump ended up right on top of the IFS front diff. I need to start looking for a front sump, but I haven't yet. Not sure how much up-travel you have in the front end, but I'm sure you know to keep an eye on it.
Nice work - keep it up
Old 05-19-2009, 08:16 AM
TNRabbit's Avatar
It's going to suck to have to listen to this all day:
http://www.youtube.com/watch?v=xwf5O3r-1vo
http://www.youtube.com/watch?v=4cdL2iJ7dcw
http://www.youtube.com/watch?v=QENa31oMjgY
http://www.youtube.com/watch?v=8LoBWSzA2qo
Old 05-19-2009, 08:36 AM
RMA
RMA's Avatar
N8 the ls 400 has the front sump ,
I think you can do it in 1 month if you are using the auto from the lexus along with the wiring and ecm all from the same lexus .
gennro do you have pics of the rear sensor , did you drill for it on the tailhousing , or what did you end up doing.
Old 05-21-2009, 07:47 PM
  #25
gennro's Avatar
Engine should be running tomarrow!!
Old 05-21-2009, 07:59 PM
  #26
RMA
RMA's Avatar
Gennro interested in the tranny part of your swap , do you have any pics of the frankenstined tranny.
I know you swaped output shafts , did you use the 4 prong rotor from the lexus.
Did you do the swap of the output shafts your self or tranny shop.
Old 05-22-2009, 06:11 AM
  #27
gennro's Avatar
I did all my own work, that speed sensor is not important except for running the speedometer so i didn't hook it back up or mess with it at all.
Old 05-22-2009, 08:26 AM
  #28
TNRabbit's Avatar
I thought the speed sensor kept the engine from revving above 2000 rpm unless it had some sort of pulse signal...?
Old 05-22-2009, 02:33 PM
  #29
gennro's Avatar
None of them do that, BTW the engine is running and revs above 2000rpm
Old 05-22-2009, 02:59 PM
  #30
RMA
RMA's Avatar
Glad to see you were able to get it going .
Will you be posting any details here or no!
Old 05-22-2009, 03:15 PM
  #31
gennro's Avatar
I'll post up all the wiring information once i get it all done. Same as with cooling etc. Everything else is pretty straight forward. I'm not going to waste my time with the small stuff which anyone attempting this should already have most of the know how, tools, and skills required to do a swap of this magnitude.
Once you have the wiring information the engine is cake to wire up. I'm still in the process of testing stuff out and figuring out the rest of the wiring. The engine wiring is not quite as simple as a 22RE, but its not bad.
Old 05-22-2009, 03:20 PM
  #32
toylocost's Avatar
Location: Yotatech, because Pirate is too expensive. NorCal.
Are you using the Lexus ECU? And how are you doin the speedometer and tach? Would retrofitting the Lexus gauges be worth the work?
Old 05-22-2009, 03:56 PM
  #33
TNRabbit's Avatar
I know you run the tach off one bank of the distributor (it has two, four-cylinder distributors on the front of each cam housing) if it's a 22re truck, but I'm not sure how you would do a 3vze tachometer...?
Old 05-22-2009, 04:00 PM
  #34
RMA
RMA's Avatar
I also read you could use a 4cy cluster in place of the 6cy one, something about the pulses .
Old 05-22-2009, 04:50 PM
  #35
toylocost's Avatar
Well cuz it has 2 distributors. You just use one it does 4 cylinders. Same RPM readings on half the engine.
Old 05-22-2009, 08:31 PM
  #36
gennro's Avatar
Yes, you can use the tach signal off of one of the igniters to get a 4cyl tach output.
Old 05-23-2009, 01:43 AM
  #37
RMA
RMA's Avatar
Also one guy at lextreme was having problems with his lexus tranny not changing gears while in low range because he did not use the speed sensor .
http://www.lextreme.com/forums/showt...light=transfer
Old 05-26-2009, 07:57 PM
  #38
BlackedOut90's Avatar
The transmission is a A30-41LE out of a 1992 Lexus SC400 and the transfer case is out of a 1986 Toyota Pickup.
the t case will bolt up to the lexus auto tranny?!?
Old 05-26-2009, 08:22 PM
  #39
RMA
RMA's Avatar
this is from his 1st post
I'll be using the A30-41LE 4 Speed auto-tranny with a A30-80 Transfer case for now. I had to swap out output shafts from the A30-80 to the A30-41LE to install the transfer case. Eventually I will install an inchworm adapter and run a 23-spline grear driven transfer case using the marlin gear kit with 4.7 gears.
Old 05-29-2009, 05:13 PM
  #40
RMA
RMA's Avatar
any updates , how is she running .
Quick Reply: 88 Toyota 1UZ Swap plus MORE!!!!
