Engine Swaps Swapping an engine in your Toy, here is where to learn how
3vze auto to manual
Old 09-09-2008, 02:00 PM
jvc971's Avatar
3vze auto to manual
i just did the 3vze auto to manual trans swap.
all you need is;
clutch bracket
slave cylinder
master clutch cylinder
clutch line
manual tranny
crossmember
shifter sensor from auto tranny
clutch
flywheel
the stock ecu will work fine.
you will have to get the rear driveshaft cut and lenghtened because the auto tranny is 3in longer than the manual one.
Old 09-09-2008, 02:02 PM
jvc971's Avatar
i am having a problem by the slace cylinder is not going far enough and my gears are grinding and my shifter doesnt have the shifter gromet that goes under it.
Old 09-09-2008, 06:12 PM
jvc971's Avatar
ok i found out that its not the slave its that there was no tranny fluid in it. i am going to go buy and put some in it tomorrow and see if that made a difference
Old 09-09-2008, 06:42 PM
fillsrunner4's Avatar
all you need is;
clutch bracket
slave cylinder
clutch line
manual tranny
crossmember
clutch
flywheel
Pedal assembly too but thats a given. could always make your own too
Old 09-10-2008, 11:37 AM
jvc971's Avatar
ok i bought a new
clutch
flywheel
slave cylinder
master slave cylinder and just put a gallon of tranny fluid in my 5spd. trans.
it is still grinding.
i have a pedal assembly out if a 87 toyota pickup 4cylinder in my 89 toyota v6 4runner.
any ideas what it is?
Old 09-12-2008, 08:14 AM
Adam F's Avatar
What kind of "grinding" is it? Grinding between gears, or grinding all the time?
Could be that you damaged the gears from running it with no oil.
Could be that your clutch isnt fully engaging. You need to adjust the slave cylinder rod or clutch pedal to get full travel.
Old 09-14-2008, 07:59 AM
jvc971's Avatar
it is grinding when trying to go into reverse but it wont go into first with the engine on. the clutch is fully adjusted out.
Old 07-28-2019, 12:31 AM
Captskybax's Avatar
What was the cost estimate of the conversion?
Old 12-31-2023, 05:27 AM
cmorla23's Avatar
Help after swap auto to manual transmission
all you need is;
clutch bracket
slave cylinder
clutch line
manual tranny
crossmember
clutch
flywheel
How can I put the cruise control and 4wd back into operation after swapping from auto to manual in a 3vz?
Despite having the electrical diagram, I have not been able to put these elements to work, help
AndYota
08-10-2015 09:19 AM
jbandt
08-03-2015 03:23 PM
TransAmBandit
07-28-2015 11:30 PM
KBar
07-13-2015 06:01 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 3vze auto to manual
