Engine Swaps Swapping an engine in your Toy, here is where to learn how
3RZ swap.. Clutch and fuel question
Old 02-14-2014, 03:36 PM
Tomuchtorque's Avatar
I'm in the middle of a 3RZ swap from a 98 Tacoma (two coil)
I'm wondering what fuel line size to get for y hard lines?
My donor truck didnt have any and my 4runners were trashed so I want to run all new but not sure what size main and return are?
Secondly:
What clutch can I run?
I know the 3rz clutch and everything is used for the swap but could you use a W56 clutch and flywheel? Any problems in doing that?
Thanks for any info
Old 02-14-2014, 04:51 PM
Hadmatt54's Avatar
5/16 is plenty large enough for fuel and return!
W 56 clutch and flywheel off of what?
I'm not sure what you are asking? If you are asking if your engine originally had a W56 behind it and you want to run an "R" series transmission, can you use the existing clutch and flywheel, the answer is yes!
Old 02-14-2014, 05:22 PM
No I'm asking if I can use a clutch and flywheel that came with my W56 because its brand new in box and a new Tacoma clutch just clutch kit is $235 from parts store so can I run the 85 clutch and flywheel for my W56 or do I HAVE to run the taco stuff
Old 02-20-2014, 06:13 AM
Utah4Runner86's Avatar
I'm in the middle of a 3RZ swap, I just bought an Aisin clutch kit on Amazon for $190. There's one for $150 if you're willing to wait a month for them to ship it.
Old 02-20-2014, 05:17 PM
Hadmatt54's Avatar
The clutch and pressure plate that came with your w56 may not fit. You will have to see if the bolt pattern on the pressure plate is the same as the 3rz flywheel.
Old 02-20-2014, 05:59 PM
mel63's Avatar
You need to install a flywheel and clutch assembly for the 3RZ.
smthwsn357
05-01-2024 07:28 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: 3RZ swap.. Clutch and fuel question
