Engine Swaps Swapping an engine in your Toy, here is where to learn how
22re and 22rte block?
Old 02-23-2010, 04:16 PM
ethanp123's Avatar
wondering if a 22re and 22rte have the same block? i know they use different pistons
Old 02-23-2010, 04:27 PM
annoyingrob's Avatar
If you're talking about 85+ blocks (AKA, the LASRE block) then yes. The RE has the blanks for the oil feed and drain for the turbo, they just need to be drilled and tapped. The oil pump and front timing cover are SLIGHTLY different, but for all intents and purposes, they can be considered the same.
Old 02-28-2011, 07:50 PM
wrxnefx06's Avatar
Don't mean to hijack this thread, but if I have 22rte block could I buy a rebuild kit for the 22re - pistons/rings and bearings and slap it all together, plug the turbo inlet hole and call it good? I will be putting a 22re head on it of course.
Old 03-03-2011, 08:14 AM
Yes you could. The turbo oil feed can be plugged with a bolt, the drain you might need to fabricate a plate for it.
I know on my JZ motors, the oil drain is actually the same shape as a standard garrett T3 oil drain, so you can use standard fittings on them. I haven't measured the RTE drain, but I think it's the same. You might be able to get away with buying a garrett oil drain fitting, stick a large bolt in the threaded part, and bolt that onto the side of your motor as a plug.
Dakotaneu
07-27-2015 12:03 AM
toofly1999
07-25-2015 07:09 PM
kcaudill
07-20-2015 12:06 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 22re and 22rte block?
