4Wheeling 101 Discussion pertaining to the proper use of your off road gear and recovery techniques
One wheel danglin'
Old 09-20-2009, 06:40 PM
4bangercraig's Avatar
One wheel danglin'
So I went 4 wheelin out at McCain Valley this morning. I went past the OHV staging area, past the campgrounds, and set out down a little trail through BLM land. (The place is riddled with 'em, many of them open to offroad activity, some of them dead-ending into the Manzanita Res.) I took the trail back into Lark Canyon OHV Park and went as far as I possibly could, through some hairy little high angle rocky turns, until I finally had to turn back. What finally beat me was this:
There was an unclimbable rock to my right that forced me to the left of the trail. To the left of the trail was an upward sloping rock and then a berm sloping up at a 35-40 degree angle (the sort of berm you might bank off of on a dirt bike). I tried putting my left front tire up on the rock, but as soon as I did my rear right tire came two and a half feet off the ground and the view out my passenger window became sand and rock. I tried squeezing in below the rock and then heading up the berm with my left front tire (had to avoid that rock to my right) but the same thing happened. I got real nervous looking at sand out my passenger window, and I didn't like the fact that my locked rear diff had that left rear tire spinning in the air at the same rate as a tire that was pressed into deep sand by three thousand pounds of truck. Seems like a great way to snap an axle. So I backed off and turned around. But it's killing me- because I'm sure a good enough driver could have gotten through that spot.
So all "get a solid front axle" comments aside, what do you do when you just can't articulate well enough to keep all four on the floor?
Old 09-20-2009, 07:00 PM
seanmearse's Avatar
When you cant keep them on the ground, change a tire! lol... But seriously, SAS or get some BJ spacers and some flexy springs.
Old 09-20-2009, 08:05 PM
tc
tc's Avatar
Or man up and just drive through it.
The stock Toyota rear axle is good to over 35's with dual cases, you ain't gonna snap one in the circumstances you describe. Unless the tire is wedged, you're not able to generate enough traction to break a rear axle.
Old 09-21-2009, 05:10 AM
AxleIke's Avatar
Yeah, the only way your rear axle was snapping in that instance is if it had some sort of defect in it. Which is unlikely.
And 3k lbs? Were you carrying a bed full of cement?
Don't worry about it. Those axles will hold just fine.
Old 11-24-2010, 06:38 AM
rattlewagon's Avatar
Pinch the seat with your cheeks and keep driving.
Old 11-24-2010, 07:42 AM
scuba's Avatar
Sig material!
Old 11-24-2010, 08:57 PM
muddpigg's Avatar
Originally Posted by scuba
Sig material!
X2.
learning is part of the fun. Keep it up, don't hestitate to get out and plan your line by foot. What do you have done to your suspension?
Old 11-24-2010, 09:45 PM
totally a bro
Staff
vital22re's Avatar
Originally Posted by muddpigg
X2.
I agree 100%
when in doubt, scout it out.
Old 11-25-2010, 10:15 AM
E-ROC's Avatar
sounds like you were alone. yeah? no? if so i would have turned around also just for safety's sake. if you had company, use a spotter and enjoy the adrenaline rush. thats just my opinion.
kouki420
09-02-2015 11:42 AM
NCRidgeRunner
08-13-2015 04:11 AM
Up&Down
08-05-2015 06:20 AM
Luvmeye22re
08-04-2015 03:53 PM
skoti89
07-06-2015 07:45 PM
Quick Reply: One wheel danglin'
