what size tires is everyone running
Old 07-02-2012, 05:53 PM
hauckster's Avatar
little bit of background info:
I'm planning on doing a sas to my 87 4runner with a 4.3 tbi and i fit 36x12.5 TSLs right now with no lift other than a 3" BL. I'm planning on doing a 3" trail gear sas with chevy leafs out back as i carry a lot of gear with me when i go out.
Question:
whats everyone running for tires size with a 3" sas kit and a 3"BL?
thanks to everyone in advance
Old 07-02-2012, 06:01 PM
jeb784's Avatar
You can clear skinny 35's
Old 07-03-2012, 06:25 PM
hauckster's Avatar
anyone else???????
Old 07-03-2012, 08:36 PM
olharleyman's Avatar
35 x 12.5 x 15 with 3.75 bs rims on 90 4runner ifs 4" lift and 93 sas 4"front 5"rear and could easily go to 37's again 3.75 bs on the rims
Old 07-03-2012, 09:23 PM
Fossilized
Staff
dropzone's Avatar
You fit 36's with a 3"BL? I'd like to see the pics of how much you trimmed...
Old 07-03-2012, 09:57 PM
TurboTruggy's Avatar
38.5's with 3inch hd TG springs also ran with negative arch regular 3's
this 4 runner is running 3inch hd TG's on 42's and 1 tons with 4inch rear with 350sbc
Old 07-04-2012, 09:23 PM
hauckster's Avatar
only took 2.5" out of the fenders all the way around rears too don't rub at all
thats all i took out
and they are on 15x10 rims with a 4" backspace so they stick out farrrrrr
Old 07-05-2012, 03:14 AM
Fossilized
Staff
dropzone's Avatar
Looks like a fender flare. I was just curious since half the IFS 4 runners out there sag like they are hauling bodies
Old 07-05-2012, 08:06 PM
hauckster's Avatar
Nope that's what 2.5 inches out of a mint fender looks like
I have 6" shackles in the rear to level that sag out
Old 09-14-2012, 06:42 AM
hauckster's Avatar
Bumpity bump
Old 09-15-2012, 08:40 PM
central4runner's Avatar
Im runnin 36 13.5 on 17s irocs with chebbis out back out of an 04 two wheeler and the fronts are lifted rears of a 1st gen pick not sure on how much lift they are. i have a 4.3 in mine and the front springs sit down quite a bit and it also moved the front axle forward about 2.5 inchs and no rubbin at full stuff and full turn. also for the rear i had to put a 1in block to level it out
Old 09-24-2012, 07:46 PM
bigarms23's Avatar
you can probably ditch the 3inch bl and use a 1inch bodylift(im running a 1inch with a 93 4.3cpi) and 3inch springs and run 37-39s
Old 11-07-2012, 04:37 PM
TOY91Runner's Avatar
Running 35x16x16.5 boggers. Dana 44 front and Corp 10 bolt rear. Used 3" lift 89 4runner rear leafs up front stretched it 3" and chevy 59" stock leafs in rear with block. Seems to be a good fit....
Old 12-16-2012, 11:53 PM
Ahbustae86's Avatar
Did you trim the rear on this runner? If so, can you post a picture of the rear fender?
Old 12-17-2012, 04:33 AM
waskillywabbit's Avatar
Needs more tire shine
:wabbit2:
Old 12-17-2012, 06:16 AM
Yeah i had to re-do my rear quarters because were all rusted out so i stretched the back wheels out a few more inches and made my own quarters out of sheet metal. Trimmed off about 3-4" from stock turned out pretty nice and got rid of that ugly fender flare and bottom bumper piece ...
06-01-2021 01:51 PM
Whatever123
09-30-2015 12:12 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: what size tires is everyone running
