Trail Gear 4" front sas kit, 4" rear
Old 11-23-2011, 04:32 PM
  #41
VANCE164's Avatar
3 inch kit is stiffer the the 4's and not quite as flexy and the height is no different to be honest I've installed both have 37's with my 4's and 35's with my dads 3's and his truck is actually a little taller and he can easily clear 37's. And Paul are you coming home at all this winter? We need to wheel at some point!!!
Old 11-23-2011, 08:17 PM
  #42
vang_22re's Avatar
Originally Posted by skunkwhat
When my truck grows up I want it to look like this. Haha
My uncle lives in Portland. He drives red 3rd gen pickup. I heard it's mostly parked
Old 11-27-2011, 11:27 AM
  #43
Link182's Avatar
spring sizes
so im looking into getting this kit as well but was wondering about the spring sizes. you said you got the 4" springs and your running 35's. I only want to run 33's so should i get the 3" springs?
any help is much appreciated!
Old 11-28-2011, 01:56 AM
  #44
Bawlzdeep's Avatar
IMHO if you're spending the money on the SAS there's no reason to settle for 33's. You can run 33's on a good IFS setup "oxymoron" and have a very capable rig. I can go anywhere my buddy goes with his SAS and he's got 35's. Granted, it takes a lil longer trying to find the right line and I might blow a CV when his truck is just crawlin easy. I'm goin with 37's and 5.29's. I'd hate to dump all that $ in it again just to want to bigger again. 33's worked out good for a while but it's pretty slugish with factory 4.30's and if I'm tearing into gears...... pretty much "go big or go home".
Good luck man
Old 11-28-2011, 08:51 AM
  #45
Link182's Avatar
ok thanks alot bro. I really want to avoid the IFS lift just casue of all the moving parts, and its just not as strong as the SAS. I just dont do alot of hardcore wheelin and think that 35's might be overkill. but thanks alot for your input it really helps!
Old 12-07-2011, 01:04 PM
  #46
skunkwhat's Avatar
Just ordered The jeep swag synthetic winch line, also got some sliders on order from marlin, from cyber monday.
Old 12-07-2011, 01:06 PM
  #47
skunkwhat's Avatar
Bumper that a buddy and I made. Had access to a jd2 bender for a little while. Used a trail gear winch plate.
Old 12-07-2011, 01:08 PM
  #48
skunkwhat's Avatar
This is with the trail gear 4" hd springs. It rides a lot better on the street, doesnt bottom out anymore with the winch and the 3.4
Old 12-07-2011, 01:12 PM
  #49
skunkwhat's Avatar
this summer in idaho
12-5-11
Old 12-07-2011, 01:14 PM
  #50
skunkwhat's Avatar
this is on the bump stop in the fron, I def need to get those 37's
Old 12-07-2011, 01:15 PM
  #51
skunkwhat's Avatar
  #52
skunkwhat's Avatar
Old 12-07-2011, 01:16 PM
  #53
skunkwhat's Avatar
  #54
skunkwhat's Avatar
Old 12-07-2011, 01:18 PM
  #55
skunkwhat's Avatar
the land cruiser, i get to pull out. I call it the land chicken
Old 12-07-2011, 01:26 PM
  #56
skunkwhat's Avatar
Old 12-07-2011, 01:28 PM
  #57
skunkwhat's Avatar
south east Idaho rock garden
Old 12-07-2011, 01:44 PM
  #58
skunkwhat's Avatar
flushed in drain plug and trail gear front diff cover
I cut down the pass side mount on the under side of the housing
Old 12-31-2011, 02:08 PM
  #59
dntsdad's Avatar
Nice truck!
I have the same truck. 92 ex cab, 3.4 swap, 5 speed, dual cases 2.8/4.7 and have just about everything now for the SAS. I will be using the 4" HD springs and wondering your thoughts about the hanger. I have the Marlin hanger and have always heard to mount it 1/2 up with the 4" springs. You said that didn't work for you and mounted it flush.
My question is, after you changed to the HD springs, any ill effects of having it flush? You angles look good but I don't know what springs you have on in each picture.
Thanks
Old 01-01-2012, 09:58 AM
  #60
skunkwhat's Avatar
[QUOTE=skunkwhat;51831869]Name:  2011-09-25_15-49-20_64.jpg
This picture has the hd springs installed on the truck. I think that the hd springs and the regular springs are the same length, although I never measured. With that said, once my regular springs broke in, the shackle angle was a little more kicked back from where it is now, which I thought was better. I think the hd springs will come down a little more but I probably won't notice it.
I don't know if the marlin hanger is the same as the trail gear hanger, I assume they are very similar, but I think i would still flush it up in the front, and maybe look into sliding the frame tube jigs as far forward as you can get them instead of centering them, to get a little more shackle angle.
If it would help I could measure the distance from the center of the front hanger bolt to the center of the frame tube jig, this way it would not matter if the hangers were the same or not. Just a thought.
Quick Reply: Trail Gear 4" front sas kit, 4" rear
