FJ landcruiser front axle for a SAS?
Old 09-05-2009, 10:45 PM
KODE's Avatar
hey yotaman, did you ever do this swap? im curious to see how it turned out..
Old 09-06-2009, 01:12 AM
yotaman's Avatar
Still in progress.
I've gotten the axle and my custom shafts made. I just need to try and find the time to work on the truck now.
Old 09-06-2009, 07:26 AM
bigt's Avatar
i have a 60 axle but im going to go mini trucks in my suzuki cause i got front and rear with spings and shocks for 250 and my 60 axle needs a rebuild.. it does have some aisin hubs on it.. i might just part and sell the cruiser or save it for a rain day build...
it would be amazing in a ifs runner cause its the only like .5 bigger or smaller than a ifs rear...
Old 04-26-2011, 03:48 PM
Toyotakid#1's Avatar
I think im going to try this with my 94 pickup! Anyone get it done?
Old 04-27-2011, 07:42 AM
  #25
cruisertom's Avatar
check marlins site there is a guy who did a SAS on a 3rd gen 4runner and used the FJ60 axle. Works well for the tacoma/4runner. I am planning on the same except flip the HOUSING not the whole assembly and cut the knuckles to get the driver side drop I need. Just can't seem to find an axle in my area. You can also use IFS hubs and get another 3" of width to get around 60". FJ40 axles are 55", FJ55 are another width and FJ60 are wider yet at approx. 57-58? I am not 100% sure on these specs just what I can remember. Mini truck outers can be swapped to all except the FJ80 axles just use the inner axle and change out your Mini truck birfield and grind the ball to get the birf to fit.
Old 01-03-2015, 09:13 PM
  #26
pickle's Avatar
Hey I noticed your comment on the warn hubs ...what's you thought here had you had problems with them ..? also will the axels drop into a 2nd gen mini truck ...I've been wondering about this as well.
Flying91
45
04-11-2024 04:39 PM
oldirtydirt
02-23-2020 09:30 AM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
yourrealdad
07-21-2015 11:13 AM
Quick Reply: FJ landcruiser front axle for a SAS?
