crossover steering tie rod ends
Old 10-08-2013, 05:35 PM
stevenf's Avatar
Gathering parts for my sas on a 86 pickup. Extreme budget. Just ordered some used trail gear high steer arms. I read the fj80 are very common tie rod ends but the stocks are cheaper. The steering will probably be a junk yard build. I am wondering if the hole in the high steer arms will fit the factory tie rod ends or are the fj80's thicker?
Old 10-08-2013, 08:09 PM
Fossilized
Staff
dropzone's Avatar
The arms are tapered for the 80 series TRE. Name:  20131008_210241_zps8f3cb11d.jpg
the steering rods are also threaded for the 80 tie rods
what rods were you gonna use?
Old 10-09-2013, 12:01 AM
stevenf's Avatar
Making my own with either round bar or tubing threaded. So the stock arms fit , they have to be drilled out for the 80 tre?
Old 10-09-2013, 12:28 AM
Fossilized
Staff
dropzone's Avatar
No the T-G arms are tapered for the 80 series TRE.
Try putting a stock TRE in the trail gear arm and I bet it is smaller.
You have left and right threaded taps or just gonna cut the ends off stock tie rods and weld those to your bar stock? Or finding the correct threaded bungs?
Old 10-09-2013, 04:39 AM
stevenf's Avatar
Most likely will have access to both taps. If not, what would the issue be with both ends being right hand taps?
Old 10-11-2013, 08:50 PM
stevenf's Avatar
Anyone??? I see the left taps are alot more money... what is the reason for having two different threaded ends and not both regular thread?
Old 10-12-2013, 03:55 AM
Fossilized
Staff
dropzone's Avatar
I see you got your answer on Pirate...
Old 10-16-2013, 07:28 PM
dsal_86Yota's Avatar
Dropzone,
you dont know how or were to find info on how to make a highsteer system do you?
Old 10-19-2013, 09:01 AM
NickL's Avatar
So you don't have to remove the TREs every time you want to do an alignment. Just twist the link tube to shorten/lengthen it.
bigjstang
08-25-2021 12:41 AM
09-04-2015 09:27 AM
Lochsa
08-02-2015 02:51 PM
ripp96
07-25-2015 02:32 PM
ShakinIt2x
07-21-2015 06:20 PM
Quick Reply: crossover steering tie rod ends
