Biggest tire size with Trail Gears 5" SAS?
The All Pro site only guarantees to fit 33's, but says you can fit 38's with trimming. I want to know with Trail-Gears HD 5" kit, what you can run without rubbing and without trimming. I also have a 1" body lift. I'm starting with 35's, but will need to buy new rubber pretty soon, and want to know what size to upgrade to. I'm thinking 37's, but I want to make sure they'll fit, and was wondering if I could go even bigger.
Thanks
Thanks
I plan to move the front spring hanger forward the recommended 3/4" I also have a 1" body lift, and have already trimmed the pinch weld on the firewall, as well as taken a sledgehammer to it to fatten it out. I wasn't even close to rubbing my 33's with the IFS 1 1/2" Ball joint spacer lift. The new perches I welded onto my front axle will also allow me to move the axle forward 1" or back 1"
84 4Runner - 4" Trail Gear springs F&R - tubbed firewall (back to the body mount) - high cut front fenders - major cut of rear quarter panel & rear wheel tub = 39.5" Iroks
Don't be scared to cut the sheetmetal
I'm not scared to cut on a dedicated rock crawler, but the truck I'm working on is a lemon and has virtually no rust, its just weird. So I don't want to hack it up and destroy it. I wouldn't be building it up even, except most the time when I need to crawl out in the field or the pasture to get cattle back in, I'm usually in my daily driver.... and we have some pretty rough terrain for the "Great Plains" Beating in the firewall however, I do not mind. I've already done about as much as I thought was necessary.
Sorry for the "stupid" questions. I'll quit bugging you guys, and I'll make sure to follow up with a post on the outcome of my SAS. My 35's I will putting on aren't more than an inch bigger than my new 33" kevlar mtr's, so I won't have to worry about 37's rubbing for a while, at least not until I'm rich or rubber gets cheaper.
Get the tg hd springs. I was running the standard tg springs with my 3.4, and winch and was bottoming out all the time, on road and off. I now have the 4" tg hd's. it rides a whole much better, has good uptravel, its just still a little taller than i want it. I think i would n't go any bigger than 4" if i was you, and wanting 37's eventually.
I already have the springs, 5" HD, but haven't bought tires yet. I won't need tires till my 35's I got for free run bald. Tires come through work from time to time though, so if I see a pair I guess I'll snag 37's. As far as cutting, again, this is my one of a kind rust-free truck without dents, so I won't be cutting. This truck isn't going into the Hammers race or Top Truck Challenge, so it doesn't have to be a perfect off-roader. And like I said, I think the om617 diesel will weigh those front springs down quite a bit, so I could potentially be at the same ride height as a 4" spring set up with a 22R....
True, that's what I'm hoping for, and I'll post up specs in my build up thread when it's finished, and also as I mentioned earlier, I already folded the pinch weld over so that's out of the way.
Here's my build thread:
https://www.yotatech.com/forums/f162...l-swap-244367/
Ive seen people run 39.5 inch tires on TG 3" springs haha but they did trim a bit.... Ive seen people with 5" springs with 38s and rub at times. Im planning an SAS on my truck but dont want to go any bigger than 37s personally
One thing to keep in mind is with a SAS, you will actually be 1" taller than whichever springs you get, in your case you'll be at 6" + your body lift. This is because the front spring hanger adds an extra 1" of lift when you weld it in.
I say, see if you can't test fit some different tire sizes that you were planning on running. Even if that means cutting out a piece of cardboard in the tire size you want to run, mounting it on the axle and using a jack to simulate the suspension travel. May look dumb, but you'll get your answers.
FWIW Heres my junk with a TG 4" SAS on 36" Iroks
I'm now running RUF (about 2" lower than TG "four inch" springs) and can RUN 39.5s with the pinch weld and firewall beat
