93-98 T100s All T100 trucks
toyota t100 sas
Old 06-24-2011, 03:29 PM
  #41
t-1hundred's Avatar
The drag link (steering box to flat top knuckle steering arm) was 4ft center to center for me. I dont know the measurement for the tie rod but any gm 10 bolt or chevy dana44 tie rod will work just fine
Old 06-24-2011, 10:49 PM
  #42
Matt3203's Avatar
thank you
Old 06-24-2011, 10:55 PM
  #43
Matt3203's Avatar
the length is goin to change depending on amount of lift correct?
Old 06-26-2011, 04:34 PM
  #44
Matt3203's Avatar
would this axle work? http://cgi.ebay.com/ebaymotors/73-83...cessories#shId
Old 06-27-2011, 09:31 AM
  #45
t-1hundred's Avatar
Originally Posted by Matt3203
yup that will work. but its not a dana 44 its a gm10 bolt but same thing basicly
Old 06-27-2011, 11:15 AM
  #46
Matt3203's Avatar
is it just as strong? will i need anything else?
Old 06-28-2011, 06:18 AM
  #47
t-1hundred's Avatar
Yup just as strong. But there are pros and cons. Like there are more aftermarket accesories for the dana44 like diff covers, gears, lockers. But the gm10 bolt is a little more common and are easier to find axleshafts. Atleast in my area it is. If you can find a dana 44 id go with that.
Old 11-10-2011, 05:02 PM
  #48
t-1hundred's Avatar
Update!
just some mods i did this past year!
rear disk conversion from T-G
installed a proporting valve and line lock for the disk set up
installed marlin's HD steering reinforcement frame plates
removed the body lift finally
finally bought a real set of tires on some DIY beadlocks there 37" boggers...
decided to paint them florescent orange
and this is my favorite mod so far!!!! bought the T-G front bumper and modified it to fit my truck
had too cut and relocate the mounting plates
also had to cut the ends off cause the T is wider then the bumper was designed for
got the weld on blinker kit from T-G for that nice clean look
Old 03-07-2012, 07:57 PM
  #49
astephenz's Avatar
Steering
Explain steering what components and how the 3.4 pump is holding up
Old 03-08-2012, 06:19 AM
  #50
t-1hundred's Avatar
Steering: i run a stock tie rod and for the drag link set up i got a flat top knuckle with a 2-1/2 rise steering arm to go on it (i purchased that from shakerbuilt.com). Then to finish it off frontrangeoffroad hooked me up with 1 ton chevy rod end along with a pitman arm to fit the chevy 1 ton rod ends.
And as for the "pump" im assuming your talking about the power steering. The 3.4 power steerings ok but its certainly not the worst. You WILL have to brace your frame though if your running 35"+ tires.
Old 03-08-2012, 10:25 AM
  #51
astephenz's Avatar
Yeah im buying 10 bolt front and 14 bolt rear today. Hoping to get them for 280 ive done swap before but had 3.0 v6 n that thing sucked. Probably do hydraulic eventually.
Old 03-08-2012, 12:54 PM
  #52
astephenz's Avatar
Your pump is steering fine when articulated no ram at least?
Old 03-08-2012, 05:59 PM
  #53
t-1hundred's Avatar
No problems here. And no ram
Old 03-08-2012, 08:19 PM
  #54
astephenz's Avatar
steering
hook it up with some good pics of front steering, axle etc...astephenz@yahoo.com
Old 03-09-2012, 10:21 AM
  #55
RogueYota's Avatar
I like it...alot. Good work!
Old 03-20-2012, 08:53 PM
  #56
T1million's Avatar
Im swapping out my landcrusier axle to a dana 44,where did you get the pitman,drag link,tie rods from? also what was your measurements on the front dana for the perch adjustment?
Old 12-30-2014, 09:57 AM
  #57
T100craze's Avatar
Newby
Looking at doing a sas on my t100 what all do I need for it? I'm a newb sorry
Old 10-09-2016, 09:57 AM
  #58
t-1hundred's Avatar
Okay guys it has been a while but i figured its time to give ya'll a t100 update!
Since then i have done the following:
*TRD supercharger with URD's 7th injector
*swapped out the stock rear axle
*swapped out the front dana 44 axle
*blew up the 5vz
(All happened in that order)😁
Currently in the middle of an engine swap😎. But for now ill just go over the stuff i just mentioned above.
I had an itch for power after the SAS and the 3.4 wasnt satisfying my need. I then hunted down a supercharger and ended up getting a 1st gen. (grey) supercharger for cheap. I rebuilt the nose and replaced the bearings that supported the rotors. I bought URD's 7th injector kit and it was plug and play. Yup that easy to install! Power was awesome compared to not having a boosted 3.4, suddenly i didnt have to down shift going up hills. The torque was awesome.
After adding the supercharger i found myself beating the piss out of it everywhere i drove the thing. Did good 1st and 2nd gear bakers too😉.
But with adding all that power i kept blowing up my stock 8.4 diff. After blowing up three diffs i was fed up with it and bought an 80 series 9.5 full float rear axle to swap in. I added 1.25 wheel spacers to get the width i needed and did 5.29 gears with a detroit locker. I was already in the middle of building another front axle to swap in place of the dana44 and knew id be going with 5.29s anyways so it kinda worked out instead of buying 4.88 to match the ˟˟˟˟ty dana44.
Speaking of the dreaded dana 44 front axle🙄.....i was sooooo tired of snapping axle shafts, u joints, going threw wheel bearings, trying to hunt down axle shafts for a gm dana44 (god damn near extinct), and the fact that i was stuck at the gear ratio 4.88 which sucked! (the highest common ratio between domestic and yota axles is 4.88). Finally just said F-it and spent the money for a custom diamond axle. Probably the best money ive ever spent to date on the truck and dont regret it at all! I wanted something strong as hell but still remain 6 lug. With tons of research and money this is the front axle i ended up with:
Brian made me a full width housing with a 9.5 LC center section and 80 series LC outter knuckles to top it off, i even had him add gussets to the knuckles. He also include some nice chromoly inner axle shafts. I then bought hellfire fab's steering knuckles to keep the steering nice and tucked away and an 80 series 9.5 third member paired with 5.29 gears and a detroit locker to match the rear😁
2 years later of hard wheelin the 5vz finally let go. Held up great with 80,000 miles of rev limiter! Right now im in the middle of swapping in a 2jz so stay tuned!
Also, can somebody move this thread to the t100 build section. Thanks!
Old 10-09-2016, 10:00 AM
  #59
t-1hundred's Avatar
Here pic with the supercharger installed
Old 10-09-2016, 10:04 AM
  #60
t-1hundred's Avatar
The front axle🙌🏻
Attached Thumbnails toyota t100 sas-image-524946644.jpg   toyota t100 sas-img_2902.jpg   toyota t100 sas-img_6167.jpg
Quick Reply: toyota t100 sas
