93-98 T100s All T100 trucks
Tacoma/4Runner/T100 R150F Compatibility
Old 06-23-2014, 06:21 PM
mbbeard21's Avatar
Ive searched and searched but can't seem to find a definitive answer to this. I've got a 1995 T100 needing a 5 speed (R150F) transmission. What all other R150F Xsmsns can be used as a replacement? (tacoma, 4runner, etc). I have another 1995 T100 R150f (bad 5th gear) that came out of my dads truck I can pull parts from if needed.
I'm aware of the Xfer case drop differences. Can I just swap the Xfer case from the one I have to the Xsmsn from a Taco/4Runner? I've been told the shifters are in different spots and it wouldn't work. But when I ask the junkyard they say 'Yep, they all work fine no problem!' Of course they don't take refunds either.....
Can anyone shed some light on this?
Old 06-23-2014, 06:29 PM
theMonch's Avatar
Where you located? I have one complete with transfer case from a 96 T100. Im in Northern NJ.
Old 06-23-2014, 07:25 PM
250000_yota's Avatar
My understanding is that the only difference between a T100 R150 and every other R150 is the bell housing, so you could probably just find yourself a good trans, swap your bell housing and transfer case on, and go.
Old 06-24-2014, 05:29 AM
mbbeard21's Avatar
I'm located in central TN. How much are you asking for it?
Old 06-03-2021, 09:03 AM
90’s toyota's Avatar
Transmission swap
I have a 1990 Toyota v6 extended cab pick up truck and the owner before me ended up doing a 4.3l engine swap and it’s pushing 300 hp and like 340 ftlbs torque and the stock r150 has lasted the last 20 years but I really wanna start looking into if anybody has tried getting like a Chevy HM290 5 speed out of a s10 and put it into the Toyota body and if it was close to the stock hole for the shifter or if it will be way off
kawazx636
10-06-2021 03:03 PM
justdifferentials
14
06-11-2017 08:36 PM
irv
10-01-2015 09:49 PM
irv
09-23-2015 08:30 AM
Hugh_Mann
09-16-2015 03:59 AM
Quick Reply: Tacoma/4Runner/T100 R150F Compatibility
