93-98 T100s All T100 trucks
oilpan gasket replacement
Old 10-19-2012, 06:30 PM
t100fred's Avatar
hey guys
Have a 96 t-100 SR5 3.4 v 6 with auto trans. oil pan and valve covers are leaking. Mostly oil pan. I really want to fix but am worried about how hard it is to do. Things are tight under there. Anyone done it and can anyone give me a blow by blow. truck has 262,000 miles and still runs great. Thanks for the help.
Old 10-20-2012, 11:36 AM
stockwell45's Avatar
I just did both the valve cover gaskets and new oil pan on mine. Yeah, it's a pain in the rear but I wouldn't say it's hard. Just time consuming.
This will help you out for the valve cover gaskets:
https://www.yotatech.com/forums/f2/r...gasket-196737/
As far as the oil pan: remove skid plates, wheels, then remove CV joints, disconnect 2 electrical connectors from front diff, 2 vacuum connectors and diff breather, disconnect drive shaft, remove the 2 bolts and the 12mm hex key from diff and wrestle the diff out. That's the fun part. Then removing the oil pan is pretty straight forward from there. I just used RTV on my oil pan and it hasn't leaked one bit, I've heard the cork gaskets can give people trouble.
I've never done either before, and I was able to do everything by myself without any real problems. Expect your truck to be down for 2 or 3 days at least to give yourself plenty of time to do it.
Old 10-21-2012, 02:26 PM
t100fred's Avatar
stockwell 45
Thanks for response. I have rear wheel drive pichup, so oil pan info won't help. If you know somone who knows have them post will you. mostly need to know if engine has to come up for clearence to remove and install. The valve covers are the same on all 3.4s i'm sure so thanks the link. Thanks again
Old 10-28-2012, 06:49 PM
waskillywabbit's Avatar
If you have a 2WD then you don't have a front diff which means it is a LOT easier.
:wabbit2:
Old 10-29-2012, 06:36 PM
RobD's Avatar
As far as I know, there isn't an oilpan gasket on the 3.4. My understanding is that it's all FIPG material.
Old 10-29-2012, 07:51 PM
toyodually's Avatar
buy a haynes or chilton manual or both. they explain things pretty good
Old 11-03-2012, 05:52 PM
t100fred's Avatar
thanks for the feed back. I will get the FIPG
Old 11-03-2012, 05:53 PM
t100fred's Avatar
thanks for the resonse
smthwsn357
05-01-2024 07:28 AM
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
smiley52
07-11-2015 05:16 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: oilpan gasket replacement
