Lifts questions t100 4wd
So today I when to the Tire shop that I always go too, about 5 miles from me,that does lift for toyota trucks also. I end up picking up a lift kit from my T100 for $140. Now this lift was taken of from another T100 4wd, but have to ask do any of you guys know who makes this kit and does anyone have any Diagram to install this kit but if not I'm just going to take it back and have them put it on. I was told that this is a 3inch front lift but came with the 3inch block but I'm going to just put the 1inch block on the level out the truck. Any HELP would be great.IMG_20130502_161131_zps428d03bf.jpg?t=1367536669
That is a Pro Comp lift kit for sure, you will have to match up some shocks, do a search
on the T100 Pro Comp lift and get some photos, maybe some instructions.
2 inch rear lift blocks are best , I removed the 3 inch blocks in my T100
If you still want a lift, the Blazeland kit will work, just gotta get the CV axles from total chaos and find some torsion bars or weld on some coilovers and I recommend a chevy spring swap for the rear, someone on here did it and it looks good.
